AVS › AVS Forum › Display Devices › Rear Projection Units › HLP5674W/HLP4674W Owners Thread/Problems/Tweaks/Service Menu/Discretes etc.
HLP5674W/HLP4674W Owners Thread/Problems/Tweaks/Service Menu/Discretes etc. - Page 77
post #2281 of 2291
Yes, heat may well be a factor. I'd imagine that a repair would cost a few hundred bucks (they'd probably start by replacing the light-engine). So it might be wiser to upgrade, especially considering the current prices on LCD's. I went for a Sony XBR 1080p LCDTV, and I'm SO glad that I did. It is so much nicer than the DLP. I passed the DLP on to my in-laws, and it's still working well for them on the original lamp.
Gary
post #2282 of 2291
Thanks Gary. That is what I am thinking. I will have it looked at to find out the possible cost. I have already started looking at the new LCDs. I have a Vizio 32 inch in the bedroom that has a better picture than my DLP had, so I may use this time to upgrade.
post #2283 of 2291
Well Gary I found out the repair was more than I was willing to spend, so I upgraded to a Vizio VF552XVT and was amazed at how much better the picture is. I haven't really looked at TVs since I bought the DLP 4+ years ago. The repair guy is even going to buy my TV for parts .
post #2284 of 2291
Very cool! Yes, it is truly amazing how good a 1080p fixed-pixel display looks, especially with a 1080p Blu-ray source!
Gary
post #2285 of 2291
I just received my lamp from Fedex and followed the general video on the Samsung site, once I removed the little cover on the back of the TV expecting to see the lamp - there was a fan.
Can anyone tell me what I need to remove to get at the lamp.
I appreciate it!!
post #2286 of 2291
I just wanted to chime in on how reliable this set has been. I bought the new HLP5674 six years ago. I recently replaced the bulb even though the first bulb was still going strong.
My next TV will likely be a Samsung based on the experience I've had with this TV. Kudos Samsung engineers!
post #2287 of 2291
I lose my blue in my picture after watching for a while..
I thought color wheel, but it's just the blue.... Any help?
post #2288 of 2291
I appreciate it!!
You probably figured this out already, but the lamp door is on the left side of the set, as viewed from the front.
-- Pete
post #2289 of 2291
I Just put another $120 into my 5674 -- definitely the last time. I replaced the color wheel myself for the 2nd time after it shattered. Took me about 30 minutes total time this time a great improvement over three hours last time. I replaced the bulb last May.
This time the color wheel was my fault -- I was sanding new sheetrock seams in the room with the set while it was on -- the fine grit in the air got pulled into the set and it didn't have a chance.
post #2290 of 2291
So I replaced the bulb on my 4674 and now only have a picture in black and white. Any ideas what could be causing this or how to fix it?
Kris
post #2291 of 2291
Sounds like a bad color wheel KGD_007.
  Back to Forum: Rear Projection Units
