Like Gilda Radner used to say...."Never mind".duh!..I just discovered that the winds had apparently moved my antenna just enough to cause the problem. After re-synchronizing the rotor, WTOV's signal is back up to where it normally would be. I should have checked this but forget that high winds can move an antenna some even if it's attached to a rotor. It wasn't enough to matter on their VHF signal but enough to mess up their high frequency UHF signal.
