I have a modded Pioner DV-737 (the DVD MAX player). Yes, it has the chroma bug; for some reason, it's not bothering me like I've seen on previous setups. Only if I carefully look for it on certain scenes can I see the jagged borders the chroma bug creates. The picture is so pristine otherwise that one is easily distracted away from the bug. Personally, I think the bug is overrated and will concentrate my own modification efforts on satellite receivers. So if you want to mod Pioneer players, you will still be rewarded with a great picture.
After researching this a bit, I believe I've uncovered the main issue with doing the mod: many video components use the ITU601 (or BT.601 or CCIR601) standard for the parallel YUV bus. This standard, while similar to ITU656, does not implement the full SAV/EAV embedded signals that the ITU656 spec. is expecting. I am searching for a satellite receiver that uses the ITU656 parallel bus so the mod can be easily done. This is proving to be difficult.
I have confirmed with Uwe at Vigatec that the deserialized video from the SDI receiver chip must conform to the ITU656 spec.
The best way to tell if you have a good modification candidate is to look for the NTSC/PAL encoder I.C. (usually made by Analog Devices, Conexant, Sony, etc.) and get the datasheet on it. If it accepts _only_ ITU656, you're in luck. If it accepts both ITU656 and ITU601, then you will need to determine which parallel bus scheme is being used. The easy way to tell is to look for pins on the I.C. which select which mode the part is in. The hard way is to actually look for the embedded SAV/EAV signals with a logic analyzer (or just hook up the serializer and pray for video to come out the other end). In any event, you will also encounter some encoders which only accept ITU601, in which case you should either search for another candidate or build a programmable logic device like Bob Cobler is doing to convert '601 to '656.
-Dylan
P.S.: If anyone would like to help me, I have a lead on DSS receivers. A reputable magazine showed a home theater install which had a Sony SAT-A55 receiver modded for SDI. If anyone has a SAT-A50 or 55 and a screw driver, I'd love to know which NTSC enocder is being used. So far, in looking at sat. receivers, I've only found ITU601 implementations.
