Originally posted by mavromatis What's the easiest way to check if the stream contains the codes? I've got a scope... what pins do I probe?
Worst case.... is there a FPGA already out there that I can buy that will add the codes? Seems like something that should be available... the guys I asked seem to not want to give away/up their secrets... :( |
I don't think it's a secret or proprietary design issue. The circuit needs are well known to any broadcast video circuit designer. The issue is there is no one FPGA file that can account for all the different DVD/STB designs. Remember the internal H sync position in relation to the data stream is not defined. Nor is the vertical or frame pulse but that's far less critical. Take something as simple as polarity - some designs amy have postive H/V and some negative or a combination of the two. Your EAV/SAV embedder must take that into account.
As I mentioned Sony did make a chip that handled the entire 601 interface. But you have to design around this chip, it's not a drop in for existing designs. I you are in the SDI mod business, you have the tools to design FPGA's and there any minor changes are mouse clicks.
Sorry if this seems not too helpful but some DVD players are simple and others are best avoided if you don't have access to these tools.
