Background: Much of this was edited, updated, and tested from the SA3250HD/SA8000HD posts by AVS Member 'vegggas'. Others were added from personal experience and suggestions, with literary license taken.
Suggested Links to SA8300HD threads/sites that may be of further interest:
Additional Items of Interest
Xnappo's SATA Expansion Databases. Tracks compatibility issues between SA8300HD/HDC (and compatible units like the 8240 series) and various SATA drives/enclosures:
Hot Topic Of The Day
TIPS & TRICKS (separated in the following categories):
Setup Wizard. UG-3 Instructions for Advanced Setup Wizard to choose TV type and resolutions, done after the box has received it's initial download from your cableco.
Removing Bars On SD Channels. Factory default displays side bars on non-HD channels. Toggling zoom modes eliminates them, but this often cuts much of image. Adding resolutions allows TV to stretch images and avoid uneven phosphor wear (burn-in). Use Setup Wizard to enable resolutions other than 1080i. Also set picture format to Pass-Through (press Settings twice, scroll to Set:Picture Format, select Pass-Through).
Settings
General Settings Option Info. After pressing Settings twice, scroll to any General Setting option and simply press Info for description/other information.
Audio Out Using HDMI Connection. UG-2 HDMI connection will automatically select 2 channel stereo if TV does not support Dolby Digital (DD). In order to restore DD audio to receiver, change automatic setting. Press Settings twice and scroll to Audio: Digital Out. Change setting from HDMI to Dolby Digital. This will force DD audio to HDMI, as well as digital/optical audio outs.
Display Format Summary. UG-5/6 Press Settings twice, then scroll to Set: Picture Format.
Auto Shut-off Workaround. Auto Shut-off feature can be defeated by setting General Settings/Timer: Turn Off option and setting Timer: Wake-up option for 1 minute later to keep unit on virtually 24/7. Useful if 8300HD is connected to Replay TV or other devices that rely on 8300HD for channel change, etc.
Recording Options.
Extend Recording Time. UG-21 Extend recording time of recording currently in progress by:
Change Recording Times. UG-21 Recording times can be changed by editing Start/End times when scheduling recording or any time before recording begins. This is useful to avoid scheduling conflicts caused by networks who think beginning programs early or ending them late hooks viewers. However, there is a problem whereby contents of buffer is incorrectly added to beginning of recording whose start time has been changed. The problem only occurs if you happen to be tuned to same channel prior to start of recording.
"Save Time" and "Until I Erase" Options. "Save Time" and "Until I Erase" are separate options designed for different purposes.
Lost or Missing Recordings. Most of us probably schedule several All or New episode recordings when fall season starts and then forget about them. However, the success of these scheduled recordings depends enirely on the title of the program matching the title when the recording was scheduled. Oftentimes, the title in the IPG changes, sometimes as often as weekly, and that can wreak havoc with your schedule. While it's impossible to attribute every lost or missing recording to a title change, it seems worthwhile to periodically check your scheduled recordings list against IPG to make sure recordings are highlighted properly.
Blank Recordings. Sometimes recording may appear to be blank when attempting playback:
Auto-Erase. The Auto Erase function should work on programs recorded AFTER it is turned on and for those programs originally recorded without the "Until I Delete" option. Previously recorded programs that were recorded without those two options should not be auto deleted even after you manually change the save time settings (except for the amount of days you set it to) because they were flagged to not be Auto Erased as space is needed.
In summary, to use the feature:
1) Turn ON Auto Erase.
2) Change Save Time for Future Recordings to something other than "Until I Erase".
You should also clean out your recordings so that you have a decent amount of working space for the above rule. If you only have 5% space left, and try to start using the feature it's not going to work because you would only have up to 5% of available working space to begin with (hint 5% is not even enough to record 1 hour of HD). Programs originally recorded with those settings will comply with the rules.
Playback Controls
Slow Motion Mode. UG-14 While viewing a recorded program, press Play 2nd time to enter Slow Motion mode.
Frame Advance Mode. UG-14 While viewing a recorded program, press Pause, FF/REW now become Frame Advance.
Fast Forward/Rewind. UG-13 Pressing FF/REW starts desired action. You can press them up to 4 times to increase the speed; 4x, 10x, 30x, and 128x.
Mimic Tivo Jump-Back. UG-14 Tivo users have gotten used to how it 'jumps back' a few seconds when you hit Play after fast forwarding. You can mimic this behavior by hitting Replay, button with curved arrow on it, instead of Play. This will bounce you back 8 seconds and resume normal speed from there.
Diagnostics
Diagnostic Mode. There are two ways to enter Diagnostic Mode:
Finding SARA Software Version. Enter Diagnostic Mode (see above item) and scroll through screens until you find one entitled "Software Versions" or "Component Information". Version number on one of those pages will be in a format similar to 1.85.14.3. Also, there are a number of different naming conventions being used and only one is really accurate in sense that PTV OS version number can differentiate SARA versions across platforms. For example, both SA8000HD and SA8300HD run SARA 1.89.18.1. However, SA8000HD runs PTV OS 6.12.18.1 whereas SA8300HD runs PTV OS 6.14.81.1. This probably doesn't mean much in big scheme of things and is offered only for information when viewing diagnostics screens.
Reboot. Unplug power cord for 5 or more seconds and then plug it back in.
Forced Reboot (without unplugging unit). On front of box, press/hold both VOL+ and VOL- , then press INFO.
Hard Reboot. Hard Reboot will refresh all available software and modules on system, as well as clear out memory cache. IPG and other data may take up to 30 minutes or more to fully download.
Last Resort (Reformat). If for some reason you can't get STB to do what you want and you've rebooted it by unplugging it, etc., this is a "last resort" item - say just before taking unit back, you can try reformatting the HDD. The format operation resets all data on the DVR, including all recordings, preferences and scheduled recordings. It is a "factory fresh" reset.
When doing the format procedure, there are times where it won't always "take" and will have to be redone again. The procedure is to get the mail light blinking from the remote control by holding down the pause button. Once blinking do not press anything else except the page down (page -) button on the remote three times while watching the display. The display should say something like HDD-1 and then HDD-2 or HDD-F. Once on the setting you want (typically the third press) leave it alone and put the remote down. In a few minutes, the DVR will reboot and reformat on it's own. Once complete in about 10 to 15 minutes (depending on RDC and FDC signal level quality) the unit will be available to be turned on, but it's best to leave it off and come back at a later time after it has completely downloaded all of the guide data and info.
Memory Info. Memory Map for 8300:
Signal Levels. General info regarding diagnostic pages and signal level data displayed:
Page 37 - Switched Digital Video
Page 38 - SDV MINI Carousel
Page 39 - SDV Session Info
Page 39 seems to display the most data of interest so far. Here is how some of the fields behave with different channel types:
Fixed QAM/analog:
Name-Status: SDV61444-Ready
SamSvcld/Type: /Broadcast
Act Time: n/a
SDV Freq: 0MHz
SDV Channel:
Name-Status: SDV61444-Pending (until lock), then -Ready
SamSvcld/Type: /Switched
Act Time:
SDV Freq: Changes depending on SDV pool that gets assigned
Once you check the data for a few channels, you begin to figure out which QAM frequencies are assigned to the SDV pool and can identify them quite easily from the data on page 1.
Miscellaneous.
Clearing Pop-up Windows. UG-18 You can get rid of pop-up windows by pressing Exit.
Program Distribution. 8300HD has 2 tuners and 2 outputs that may be used at same time. Archive To VCR option uses Composite/S-Video connection to "archive" recorded program to VCR/DVD. However, it can also be used to "view" downconverted recorded program on alternate TV while viewing different live/recorded program on main TV or recording two other programs on 8300HD. Also, depending on software version/cableco, 8300HD may be similarly connected to one device via HDMI and another device via Component to view same recorded/live program on different TVs at same time. Component/HDMI no longer work for some, but Composite/S-Video still work with Archive To VCR option for everyone.
Viewing A Third Program. No matter how many tuners 8300HD has, there are times when they are simply not enough. There is nothing to keep you from hooking up an antenna to ANT input on TV and switching to that input to view third program, to keep you from splitting your cable and running 2nd line to TV, or to keep you from running 2nd line to VCR and then to TV to view/record 3rd program.
Macro - Automate Remote Turn On. To automate remote turn-on and stay on whatever channel you previously had on (instead of a dedicated turn-on channel) without using the power button, go to General Settings/Viewer:Power On option. In list of Power On channels, select Last Channel. Now, no matter how you choose to turn unit on (except when using a dedicated wake up timer), it will go to last channel viewed. If you want to set an easy macro, make sure General Settings/Set:Power-On Keys option is set to Power/Numeric. Then in macro, choose non-existing channel (such as "000") to turn on unit, it will turn on, but not change channels.
NOTE: Some software versions may react differently when entering non-existing channel number. In these instances, some folks have had success by entering channel number followed by "Last" to tune to previous channel.
Also, those of you with on/off issues, there are more tricks you can do. Someone mentioned that they can't use channel "0" because it changes to "1", and another says that the guide comes up whenever it's powered on. Use the "EXIT" button to clear commands before they are used. Example: to power on, macro in channel "0" with single press of "0", then press Exit. The channel never changes and the guide data is quickly erased too. The "EXIT" button clears all on-screen graphics and aborts commands any time it's used.
Anamorphic DVDs.
First some background. Basically, Anamorphic DVDs are SD DVDs that have wide screen image "Squeezed" rather than recorded in letterbox format (where upper/lower black bars are wasted). This results in DVD with more resolution. While some DVD recorders/formats support inclusion of anamorphic (16:9) flag, you do not really need flag if you can view DVDs in "stretch" mode. If DVD recorder does have ability to set this flag, then "stretch" will automatically occur in DVD player.
To make this work you need to get SA8300HD to "squeeze" images. 8300HD will do this on Composite/S-Video outputs when in SD mode. Once in SD mode, Zoom button (usually #) on remote will go to "Stretch 480i" mode. This results in 16:9 image being squeezed into 4:3 space so you can record it. It is recommended you use S-Video connection on 8300 for these recordings. Note: when 8300HD is in SD mode, Component outputs will be magenta in color - so you need to be watching what you are doing through DVD recorder output.
Instructions:
New Features - 1.88.x.x (May not be applicable to every cableco)
New Features - 1.89.x.x (May not be applicable to every cableco)
Bug(s) Fixed in 1.89.x.x (Not all-inclusive)
New Features - 1.91.14.102 (From Cablevision user - May not be applicable to every cableco)
- SA8300HD DVR User's Guide
- Vegggas' original SA8000HD DVR - Cox - SARA - Setup and Review Guide thread
- SA Diagnostic Screens Explained
- Time Warner Cable - SA 8000HD & 8300HD w/ Passport software thread
- 8300HD and External SATA - It Works!! thread
- SA's PowerTV Developers Page
- SA's PowerTV CreativEdge Developers Guide
- SA8300HD/HDC eSATA Compatibility Database (SARA)
- SA8300HD/HDC eSATA Compatibility Database (Passport)
- SA8300HD/HDC eSATA Compatibility Database (Navigator)
Code:
A B C
SARA Browse By Date [curved backarrow]
Passport Echo Time Theme Search
Passport (non-DVR) Time Theme Title
Navigator Access Menu Find Shows [no label]
- Setup
Setup Wizard
Change Default Format
Reverts To 480i - Settings
Audio Range Settings
Auto Shut-off Workaround - Recording Options
Recordings With Manually Set/Altered Start Times
Checking Status Of Current Recording
Blank Recordings
Place-Holders For Future Recordings (1.88.x.x)
Potential Recording Conflicts
Auto-Erase - Playback Controls
Slow Motion Mode
Frame Advance Mode
Fast Forward/Rewind
Resume Playback - Diagnostics
Diagnostic Mode
Disappearing Diagnostic Window
Reboot
Hard Reboot
Total Reset
HDD Defrag
V/H Resolution Information
Memory Info
Signal Levels
SDV Diagnostics - Miscellaneous
Anamorphic DVDs
Bug(s) Remaining after 1.89.x.x
- Using Power button on unit (not remote), turn off power, then press both GUIDE/INFO at same time.
- Choose Easy or Advanced setup - Easy selects 1080i output only - Advanced provides options for TV type (4x3 or 16x9) and user selected outputs.
- Follow instructions on the screen. Read instructions carefully. If screen goes blank, it is trying to display a resolution not supported by TV - disable resolution.
- Press/hold Select until Mail LED lights.
- Press Vol Down (-) button - display changes to "HdSr" (HD Screen Resolution)
- Press Ch Up (+) for 480i
- Press Ch Down (-) for 480p
- Press Vol Down (-) for 720p
- Press Vol Up (+) for 1080i
- With box OFF and TV ON, press Info /Guide (on box) together, then follow on-screen directions to enable 480i and others. Cable passes 720p (ABC, FOX, ESPN), 1080i (all other HD channels), 480i (SD channels), and 480p (music channels). If you do not see difference between 1080i/720p, enable only one to minimize reformatting while channel surfing. Note: The 480i/p Widescreen options allow 8300 to stretch image. Do not enable if you use TV to stretch image.
Settings
- Fixed - Displays all content at whatever resolution you selected in Setup Wizard.
- Pass Through - Passes input signal through with no change unless you disable a resolution. For example 480i in - 480i out, 720P in - 720P out, 720p disabled - 1080i out, etc.
- Auto HDMI/DVI - If you use HDMI, this option replaces Pass Through option. Resolution is automatically formatted to scan rate supported by TV.
- UpConvert 1 - All 480i/480P signals converted to 480P. All 720P/1080i signals converted to 1080i.
- UpConvert 2 - All 480i/480P signals converted to 480P. All 720P/1080i signals converted to 720P.
- Wide Dynamic Range will render audio that will go from faintest audio level of a whisper at an extremely low level to thundering boom at ear-shattering levels giving great impact to action movies, but calls for good audio setup to properly hear normal dialog without blasting speakers during loud scenes.
- Narrow Dynamic Range keeps lower volumes at higher level while muting higher level sounds to lower level. Whispered dialog is not much quieter than explosion and all sound levels are "Narrowed" to a certain level.
- Normal Dynamic Range basically splits difference.
Recording Options.
- Press LIST.
- Press "A" to switch to Scheduled Recordings list.
- Find in-progress recording program (it will be highlighted in RED).
- Press SELECT to access options.
- Change End time to desired time.
- Press the "A" to accept changes.
- The term "Save Time" is misleading and has little to do with how "long" programs will be saved, especially when it comes to available space and "Auto Erase". It simply gives one the option to record 1-5 or All episodes of a given program and oldest will be erased when selected option starts recording, etc. This is the case wheher or not Auto Erase is turned On.
- However, if "Auto Erase" is turned On, oldest recordings (not just the oldest episodes of a given program) will be erased regardless of "Save Time" settings. If all are tagged "Until I Erase", further recording stops and message is displayed indicating drive is full.
- If you get blank screen, try selecting another recording from list, begin playback of that recording, and then re-select original recording. If it still doesn't play properly, try a hard" reboot before giving up and deleting recording.
- If you get Playback Channel screen, try a "hard" reboot before giving up and deleting recording.
- Justice on FOX airs weekly on Monday nights at 8:00 pm. When regularly scheduled recording starts, new place-holder is set for next episode, but it is dated for following Wednesday and will appear as such in Scheduled Recordings list. It is easily identified as a place-holder. When you press INFO, you get an empty display window.
- Criminal Minds on CBS and Lost on ABC both air weekly on Wednesday nights at 8:00 pm and when you view the IPG, both of these are highlighted for recording.
- Nothing is scheduled to record on FOX on Wednesday nights at 8:00 pm, so nothing should be highlighted. However, if you check further, you will see that whatever airs at 8:00 pm is also highlighted (MLB Post-Game as of this posting).
- Even though this appears to be incorrect, is it only highlighted because of place-holder for Justice and not because anything will actually get recorded. It does not need to be cancelled.
- In my test, place-holders are reset for correct day once next episode appears in IPG, usually after nightly IPG update. Others have had them reset shortly after mid-night, while still others have them wait to reset until the actual day of recording.
- It's important to note to be careful when reviewing IPG and Scheduled Recordings list for upcoming recordings, all may not be as it appears and you may inadvertently cancel recordings that are not erroneous.
Playback Controls
- One caveat. Next time you press FF, you will be given "next" FF speed, rather than FF1. If you were using FF2, hit Replay, watch some of show, and then hit FF, you will get FF3 instead of FF1. A better way might be to press Play and then immediately press Replay.
- Another way to mimic this action is by pressing Pause instead of Play to stop fast forwarding. This way, when you hit Rewind to back up to precise place to restart program, it will remain paused instead of immediately starting to play again.
Diagnostics
- Press and hold Select on front of unit until Mail light starts to flash, then press INFO.
- Press and hold Pause on remote until Mail light starts to flash (around 10-15 seconds), then press Page Up (-). On some remotes, Page (+) might need to be used instead.
- Turn off 8300 and wait 5 or more seconds.
- Unplug power cord from 8300 and wait 5 or more seconds.
- If you are resetting an external drive too, unplug it's power cord at this point and wait 5 or more seconds, then plug power cord back into external drive and wait 5 or more seconds.
- Press and hold Power on 8300 front panel. While Power is depressed, plug 8300 power cord back in. Continue to hold Power until 8300 display says "boot" and/or begins to cycle a few times (usually about 15 seconds).
- Press and hold PAUSE until Mail led is lit.
- Press PAGE down or (-), and then press LIST three times.
- Turn box off. When turned back on, formatting will begin.
- I don't think this is common knowledge, but it could save many users a lot of grief. Most failed units can be revived with total reset performed by user, depending on failure type. Instead of replacing unit and losing your shows, try this trick as last (or first) resort. This is known to reset unit no longer displaying Video, unable to lock on to one/both tuners, unable to read Hard Drive, or no longer able to get a download (display counting or hunting).
- Complete reset can be done by removing power and all connections for an extended amount of time. This means remove power cable, coax cable(s), eSATA cable, everything, so it can fully discharge capacitors and memory. This can take anywhere from 4 - 24 hours (although it MIGHT work in less than 30 Min), so pick a time that you are not going to be using unit, like overnight and while at work.
- After leaving it disconnected overnight, repower it (but don't turn it on) with just the basic connections (no eSATA) and let it sit until it gets a full download, which could take a long time. Basic OS download should be complete once you see time, or dot (depending on your settings), appear on front panel, usually within 3-7 minutes. IPG may take up to an hour, but unit could be turned on at this point.
- If it works, unpower unit and reconnect as normal, consider yourself lucky you didn't have to swap it out.
- BTW, leaving unit off while repowering and downloading is always a good idea and should be done whenver you may reboot unit. Powering on while downloading OS can result in early fragmentation of memory and erratic results.
- Set unit's MAIN/PIP channels to non-bufferable channels, such as music channel, so that drive is not being used.
- Wait a few moments to verify hard disk activity stops (listen).
- Press Power on front to turn the unit off, then wait.
- Drive should start defragging after about 5 minutes of inactivity.
NOTE: Process can take several hours to all day and will restart if content is deleted or power down sequence is repeated. For maximum efficiency, consider turning off unit, then do a front panel soft reboot (VOL-, VOL +, INFO) and leave unit powered off until you hear it go into defrag mode. Then just leave it off while you go to work, to bed, etc.
- Flash = 512Kb
- Application Dram = 64Mb
- Media Dram = 32Mb [SD versons have 16Mb Media decoding Dram]
- Mpeg Encoding Dram = 16Mb
- Non-Volatile Memory = 8Kb
- ANSI SCTE 40 2004 "Digital Cable Network Interface Standard" establishes "acceptable" levels. Free download from SCTE Website.
- Digital QAM carrier, STB Input Level: -12 to +15 dBmV for 256QAM and -15 to +15 dBmV for 64QAM.
Minimum S/N: 33 dB for 256QAM, 27 dB for 64 QAM and 43 dB for Analog. [Also known as C/(N+I).] - FDC QPSK carrier, STB Input Level: -15 to +15 dBmV
Minimum S/N: 20 dB - RDC QPSK reverse carrier, STB Output Level: +25 dBmV to +53 dBmV. (+85 to +113 dBuV is specified in referenced ANSI SCTE 55-2 2002.) Since return loss back to neighborhood node will vary depending on where you are in power divider/amplifier chain, RDC value will be automatically adjusted for more/less equal strength as received at node. If RDC is at MAX, it may have run out of oomph....
- CURRENT FDC (Forward Data Channel) refers to I-N channel used to download software and program guide info to unit.
Level: Should be -15 to +15 dBmV
S/N: Should be 20 dB or more - CURRENT RDC (Reverse Data Channel) refers to I-N channel used to send user's PPV/On-Demand and other commands back to node.
Power: Varies depending on where you are in cable power amplifier/divider chain
Delay: Signal Propagation Delay from unit to node (Q: One-way or Round-Trip?) - CURRENT QAM refers to currently tuned video channel:
Level: Should be -12 to +15 dBmV for QAM256
S/N: Should be 33 dB (or more) for QAM256 [This is more important than level]
Seconds: How long channel has been tuned.
Corr Bytes: How many bytes were detected in error and corrected since first tuned
Uncor Blks: How many data blocks that failed parity check, but could not be corrected.
Errs Avg/Inst: Average and Instantaneous Bit (byte? block?) Error Rates.
Fixed QAM/analog:
Act Time: n/a
SDV Freq: 0MHz
SDV Channel:
Act Time:
Miscellaneous.
Anamorphic DVDs.
Instructions:
- With TV tuned to 8300 input, turn 8300 off.
- Press both Guide/Info on front panel of 8300.
- Setup Wizard will come up - Simply press "A" to go into SD mode.
- Do Hard Reboot (described earlier).
- Select program to be recorded and make sure DVD recorder is ready to record.
- Start DVD recorder, play program on 8300, and press "#" once to get into Stretch (actually Squeeze) mode.
- When done and ready to return 8300 to regular HD operation, go through Setup Wizard again. This time press "B" to set up HD mode with desired resolutions and then do a Hard Reboot again.
- Enhanced HDD Spin Down - After 15 minutes of inactivity between 1:00am and 1:15am, the HDD will spin-down without powering off the STB, and a screen saver with an MSO configurable logo/graphic will be displayed while the HDD is spun-down. If an external SATA HDD is attached to the DVR, it will also spin down when the internal HDD spins down.
- Currently Recording Option - When the user selects a currently recording program from the Recorded List, DVR will always display a Currently Recording Program Options screen with “Play from beginning” as the default highlighted option.
- Kick Out To Live - Let's say you schedule the recording of a program and go out for dinner. When you get home, you begin watching the recorded program from the beginning while the rest is still recording. When the recording ends, you are no longer 'kicked out' of your viewing.
- Live Or Time Shifted Video Indicator – Added the API for indicating whether user is watching Live or time-shifted video.
- Activated Front Panel AUX Input - Front panel auxiliary input is activated.
- Macrovision On AUX Input – Turned on the macrovision protection on AUX input.
- Return To Live Button - While watching a DVR recording playback, pressing the LIVE remote button will tune the last Live TV channel that was previously viewed.
- 4th FFWD/REW Speed – Adds a 4th fast forward and rewind trick mode speed at 128x. A fourth arrow will be displayed on the trick mode banner for each direction.
- Broadcast Flag – Broadcast flag is activated.
- 1394 Support On 8300HD – 1394 port is active on 8300 HD boxes.
- Improved Picture Quality With "Copy to VCR" Recording - This was inadvertently broken in version 1.87.19a and then inadvertently fixed in version 1.87.27, which was not widely released. Most users are probably seeing it with version 1.88.x.x, so it has been included in ths list even though it is not a new feature.
- Support for Daylight Savings Time (DST)
- Second line of text now includes show's rating if available.
- Categories (Talk Shows, Sci-Fi) are now shown in description details.
- NEW Flag now displayed in IPG (displays on date/time line in Menu and on last line of Program Description). Note: requires Tribune Data Version 2, otherwise all programs may be listed as NEW.
- Memory management improvements coupled with application server settings to prevent loss of IPG data and improve 3rd party app loading.
- Switched Digital Video (SDV) support.
- Recording future-dated episodes provides options for those wanting to record episodes other than First Run, but not all rerun episodes:
On this channel this day in this time slot
On this channel at any time
On this channel any day in this time slot - Program description is now available with Info button while watching recorded program instead of only showing Playback channel. Note: Cableco option.
- If you block a rating, lets say PG-13, then all references anywhere in system to any program with PG-13 rating says "Title Blocked" until you enter four-digit code to unlock system.
- DAY UP and DAY DOWN buttons on remote (if you have them) are fully operational.
- If you enter channel number that doesn't exist, rather than flashing ??? in channel number field and then doing nothing, it instead switches to next channel above channel you requested.
- Enhanced Channel Maps.
- MPEG Splicing API on all DVR boxes to support Liberate “On Ramp/OCAP".
- High Resolution screens on 8300. Note: Not recommended for deployment at this time.
- Fix for On-Demand Quick button.
- EAS fixes within ATI drivers.
- Turns On In 480i Mode - If General Settings/Viewer: Power On is set to HD channel or Last Channel (if that was HD), unit used to be in 480i mode when you turned it on. If you then tuned to an SD channel and back, it changed to correct HD mode. However, this could be minimized by setting Power On option to SD channel. It used to then power up in correct mode and change to HD when you tune dto HD channel. Another workaround was too simply cycle through zoom modes using "#". You no longer have to do either.
- Start From Beginning/Kick Out To Live - If you select a recording in progress from Recorded List, you get Start From Beginning option. If you select this, you can watch recording through to end without getting "kicked out to live" when live program ends. However, if you now simply tune to desired program and rewind to beginning, you no longer get "kicked out to live" when program ends.
- Padding Start/Stop Times - Start/Stop times for scheduled recordings set for more often than "once a week" can be altered. However, any changes had to be made while scheduling those recordings. Once scheduled, they had to be cancelled and rescheduled with desired changes. Now changes are saved without need to cancel/reschedule.
- Start/Stop times for scheduled recordings set for more often than "once a week" can be altered and changes saved. However, changes for weekly or less frequent recordings are only applied to next scheduled recording and not saved for future recordings.
- When switching from live TV to previously recorded program, channel indicator does not change to Playback channel number, it remains where it was before switching. Might cause some confusion.
- Issue not resolved (same as before): When you are in FF mode and hit Replay, then hit FF again, you go to next higher FF step instead of FF1. When you are in top step FF and hit Instant Replay, then hit FF again, you go to Play instead of FF1.
- When Auto-erase is on, "NOT ENOUGH SPACE" screen may be shown.
- Cancelling changes during editing may remove program from Series recording list.
- Unit display and channel banner indicate recording in progress, but program may not be listed in Recording List.
- "NOT ENOUGH SPACE" overlay does not display when editing future recording and disk is full.
- Wake-Up Timer uses incorrect duration during HDD Spin-Down.
- End time of scheduled recording not extended past end of program.
- After firmware upgrade, video may be output via Composite when unit is off. Simple reboot will fix this.
- Multiple bookmarks so you can resume any recording from where you left off.
- Recorded show info when hitting the info button during playback.
- Jumps back when you hit play while fast forwarding in speeds 3 and 4.
I suppose I can add it to make it easier to find since I didn't see it on the page 2 link you provided. Check out the change and see if that's what you wanted. Thanks.
