Need a wood-finished sub for WAF. Have 2000 cu-ft room. Almost all usage will be movie viewing vs very little music listening. These 2 subs have entirely different design approaches, but both seem to be well regarded. SVS is much larger, ported, less amp power. Velodyne is super small, closed box, but with very high amp power.
Which sub has higher output at driver bottoming level (regardless of distortion)? In other words, most woofage for movie low freq effects. Which sub has lower bass extension? I suspect I'll get a lot of SVS recommendations - any Velodyne fans out there? Any other wood-finished subs below $1200 I should consider?
Max
Max
