| Ed, I commend you on your want for continuous improvement, but as with all things, the biggest impression is the first. |
It is highly unlikely that the ground plane session will do anything but confirm the existing indoor near-field data, albeit with room acoustics completely removed as a variable.
Based on the near-field data set, the ground plane session will 99.9% likely reveal the PB12-ISD to extend deeper and exhibit higher clean (i.e., distortion limited) output below 25 Hz, and the STF-3 will exhibit equal or higher clean output above 30 Hz. They should both have about the same dynamic output limits. I'll probably throw in power compression too.
So with respect to first impressions about the objective data set, I can't see much changing. The data will simply be more definitive, and more immune to criticism.
| When you go back in the spring, I would imagine at least one of the companies will say, "wait, we made some improvements that we haven't noted". Both companies claim to make changes on the fly. |
Improvements may exist in both models, but this exercise will only amount to a clarification of the objective data in an existing review. It will not be a new shoot-out. Retaining the original players is the only way to accomplish this fairly, especially since the existing subjective impressions for music/movies will stand.
Ed
