AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › S/A Explorer 8000 - How to Format HD?
post #1 of 2
I use Brighthouse Networks in Orlando, FL and would like to re-format or defrag the HD in my Scientific Atlanta Explorer 8000 box.
The instructions I've tried (with no results) are as follows:
Using the REMOTE CONTROL Push CBL button
Then hold down Pause Button until you see a Green Flashing light on box
(This never has worked... No flashing lights nadda)
Push the Page down (minus -) Button once
Push the List Button 3 times
So far NO LUCK... Any ideas?
post #2 of 2
http://www.avsforum.com/avs-vb/showt...hreadid=473669
You should pick a forum and stay with it. ;)
This thread is locked
