AVS › AVS Forum › Gaming & Content Streaming › ReplayTV & Showstopper PVRs › ClearToLand's Picks For Best Answers to Common ReplayTV Questions:
post #1 of 11
PLEASE DO NOT REPLY TO THIS THREAD!
This is a "Work-in-Progress" Document!
  1. DHCP Server / ReplayTV Dual IP Bug (2004) - sfhub
    DHCP Server / ReplayTV Dual IP Bug Revisited (2005) - sfhub
  2. "Please wait" failure modes other than HD - dstoffa
  3. Duplicate ISN Problem - j.m.
  4. 5xxx IR Receiver Alignment - ClearToLand
  5. Please Help: DirecTV Receiver D10-200 (D10-300) - stern_keefer
    Fix For D10-100 Local Channel Changing Problem - DosMan
    ReplayTV using serial link w/newer DirecTV receivers - DosMan - Web Page
    ReplayTV KnowledgeBase Article: "Which satellite receivers support serial control?" - DosMan
    DirecTV Satellite Receivers Compatible With ReplayTV Serial Data Link - rm -rf *.*
  6. Pictures of 5000 Series On-Screen Displays - Loren Kruse.
  7. 4000 vs. 5000 Series Differences - Paul Bruneau
  8. TiVo Series 2 vs. ReplayTV 5000 Comparison - ClearToLand
  9. ReplayTV Software Descriptions & Links [Major] - f2000Keith
    ReplayTV Software Accessories & Add-Ons [Minor] - ClearToLand
  10. FTP Image Server - Ghoul
  11. Re-route ReplayTV IDE Cable to Improve Airflow - icecow
  12. Multiple Replay Scheduling for the Methodically Challenged - ClearToLand
  13. THEME-Based Recording Priorities - Various
  14. Pushing Weather Radar Photos to ReplayTV via DVArchive - herbert
  15. Multiple ReplayTV, a Modem and a Crossover Cable - Various
  16. Voluntary collective study on ReplayTV ZONES codes (for a better FAQ) - icecow
    Voluntary collective study on ReplayTV ClawFoot Portal functions (for a better FAQ) - icecow
  17. Where was "whiney know-it-all" Jeff D during Reading 101? ;)
  18. No fuss 50xx Harddrive Upgrade for determined newbies - icecow
    $80 Out-of-Warranty Factory Repair *OR* D-I-Y HD Upgrade? - ClearToLand
  19. Configuring Remotes For Multiple ReplayTVs in One Physical Location - Various
    How to control multiple Replays in the same location - Various
    How To Run 2-4 Replays Individually From One Replay Remote - drlava
    URC-6131 & Advanced Programming *WITHOUT* JP1 - ClearToLand
  20. Using Extract_RTV on 4xxx and 5xxx Drives - FlipFlop
    Is There a Way to Copy a New Image, But Keep the Existing Mpeg Partition? - FlipFlop
  21. Avoid Interrupting a Disk Write When Performing a COLD BOOT - ClearToLand
  22. Simple fix for some of the infinite reboot problems... - Jeff D
  23. Reverting to Your Previous Software Build - j.m.
  24. Setting Up WiRNS to Preserve CA/IVS on a 55XX - moyekj
  25. Perl Script - WiRNS Initiated Net Connect - moyekj
    Workaround for 5xxx failure to reboot every 7 days? - j.m.
  26. Channel Guide Updates Only Next 24 Hours for Program Changes - barmar
  27. First Connect via Modem After Initial Setup via Broadband Bug - sfhub
  28. Troubleshooting ReplayTV's 2 HTTP Servers - sfhub
  29. Modem-Only ReplayTV Connects via Broadband Through PC - richardtallent
  30. How to Revive a Seemingly Dead ReplayTV Tuner - Crunchy Doodle
  31. How Exactly Does "Commercial Advance" Work? - Various
    Does Show|Nav Use the Same Marker Reference Points as Commercial Advance? - Various
  32. List of things that screw with 2.4 GHz WiFi-B, G - SMMinke
  33. 50xx/55xx Series Pixilating, Skipping, Locking Up and Re-Booting - Mikeyboy
  34. Current GetShellCommands - ClearToLand
  35. ReplayTV Disk Fragmentation (or the lack of) - Various
  36. ~~~~~Demarcation Line~~~~~
  37. ASCII Character Equipment Layout Diagram Revisited - TheDreamer (Sorry Max - Lawrence's diagram is GORGEOUS - for ASCII that is)
    ASCII Character Equipment Layout Diagram - MaxH (When a newbie can't verbally explain their wiring layout, have them edit Max's diagram in Notepad and re-post)
  38. Quickest way I've found to do a search on AVS - icecow
  39. Posting and You - A Multimedia Guide for Newcomers to Forums - ClearToLand
  40. How to Ask Questions "The Smart Way" - ClearToLand
  41. MAJOR (IMO) ReplayTV "Events" That Have Been "Passed Over"... - ClearToLand
  42. .
3782 Views - 04/15/2006 @ 19:08
3378 Views - 01/29/2006 @ 16:10
3087 Views - 12/05/2005 @ 12:53
2700 Views - 10/07/2005 @ 00:50
2314 Views - 08/20/2005 @ 17:00
2180 Views - 07/19/2005 @ 18:05
1969 Views - 06/11/2005 @ 15:30
1683 Views - 05/10/2005 @ 18:45
1332 Views - 03/05/2005 @ 11:55
0854 Views - 01/14/2005 @ 14:55
0431 Views - 12/04/2004 @ 13:20
post #2 of 11
Where's 17?
The cool thing is I learned something from this... apparently you can make a list in UBB, cool! Thanks for teaching me something. -)
post #3 of 11
  1. Enable Commercial Advance on a 55xx running a software version < 144:
    Code:
    regedit setval SysConfig/DefaultPlayback CommercialSkipEnabled 1
  2. Enable Internet Video Sharing on a 55xx running a software version < 144:
    Code:
     regedit setval Software/Apps/Internet InternetEnabled 1
  3. Enable ShowGuard on a 50xx or 55xx:
    Code:
    regedit setstr Software/Apps/ReplayChannels EnableShowGuard TRUE
    regedit setstr Software/Apps/ReplayChannels ShowGuardTime 5
  4. Enable SportsGuard on a 50xx or 55xx:
    Code:
    regedit setstr Software/Apps/ReplayChannels EnableSportsGuard TRUE
    regedit setstr Software/Apps/ReplayChannels SportsGuardTime 90
  5. Restore the PREVIOUS software version on a 50xx or 55xx:
    Code:
    cdsys
    mv boot.state boot.state.bak
    reboot
    WARNING: If there is NO previous software available on your ReplayTV, this command will render your ReplayTV DOA! :eek: :o :mad: :(
    EXPLANATION:
    • The "cdsys" command automatically changes to whatever sys directory the ReplayTV is currently running from (i.e. sys1 or sys2).
    • The "mv boot.state boot.state.bak" command renames a file critical to the boot process, which causes the ReplayTV to think the current software is corrupt and revert to the backup on the next reboot.
    NOTE: Once the Net Connect completes, SHUTDOWN WiRNS. Remove the two commands above from your "shellcmds" file before continuing to use WiRNS. If you fail to do so, the next time the ReplayTV Net Connects will be its last until you re-image the drive.
    DISCLAIMER: Warning! This procedure, while tested successfully on a few ReplayTVs (YMMV, of course), does involve some degree of risk. Please understand that if something goes wrong, you will likely have to re-image your ReplayTV's hard drive--losing all recordings etc. Moreover, while unlikely, it is possible that this procedure could render your ReplayTV permanently inoperable. I will not be held responsible for any damage caused by the use or misuse of this information. Use at your own risk! Source
  6. Copy the ReplayTV Registry values to the Photo Partition to allow d/l and inspection via a PC:
    Code:
    cp /name/system/user/Registry/ /name/storage/Photo/
  7. Reset Parental Control:
    Code:
    regedit setval Software/Apps/ParentalControl UserPin xxxx
  8. .
To Be Continued...
post #4 of 11
BUMP to prevent archiving...
post #5 of 11
If you don't bump every link in your list then the list becomes useless.
..or update some of the links in the thread to point to the archives.
Right now there's some bad links in the list.
(I'll delete this post in a day or two)
post #6 of 11
I'll volunteer to bump 1 thru 10 every 2 weeks.
post #7 of 11
I think he doesn't want people to post in this thread. (That's why I said I was going to delete my post(s) within a day or two.
I think my idea of bumping every post is flawed.
It makes MOOcho more sense for him to update the links in his original post after they enter the archive (where they change to a new URL).
Whichever way, he has some dead links that should be addressed or his list will be thought of as antidated.
post #8 of 11
No longer true, because Mr. Bott's "new and improved" software now recognizes the "most recent" archived posts and his new "Second Chance" logic actually finds the original post. [MUCH BETTER than his original attempts where "Duplicate Keys" were either discarded or overlayed...] :eek:
...Right now there's some bad links in the list.
You also mentioned this after the last archive.
*IF* you would be so kind as to LIST the bad LINKs in a PM to me, I'd be most thankful and would gladly correct them.
...(I'll delete this post in a day or two)
Thank you! :)
post #9 of 11
Please (voluntarily) delete your post ASAP.
Thank you...
post #10 of 11
ok
post #11 of 11
Originally Posted by lizard_boy
ok
That's Not Nice.
  Back to Forum: ReplayTV & Showstopper PVRs
This thread is locked
