AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Marantz SR7400 and Aura Shakers?
post #1 of 5
I have a SR7400 and tried several times to get 2 shakers to work hooked up to an old separate receiver/tuner. I split the SW signal and into a L/R input on the old receiver and all i get is the signal going to the SW.
. I have my 602 set to small yes to sw to 80MHz
Who can help???
post #2 of 5
Have you tried setting it to large and hooking up to a regular channel instead of the SW channel and change SW to no. If you're only feeding it a signal below the X-over of the Marantz why do you need a sub setting on the 602? If you've got the shakers hooked to a channel other than the LFE with those setting you're not sending anything because you've shifted it all to the LFE. You're sending it a mono signal so any channel should work once set to large and no sub..
post #3 of 5
I had a denon avr3300 and had it hooked up this way my HSU and shakers worked together. Now with the marantz hooked up I have problems sending the LFE signal to the second receiver. My setup is the same B&W 602's and HSU , Aura , all that has changed is a new receiver the SR7400
post #4 of 5
I thought the 602 referred to a Onkyo receiver as the old receiver not your speakers. You've got the Marantz set properly. Does the receiver for the shakers have large/small settings? My post was intended for that receiver not the Marantz. Have you tried changing which side of your y splitter the sub and second receiver are connected to. That would show if the y is bad.
post #5 of 5
no I will try that tonight. as i mentioned the only thing different is the Marantz. I did notice when I turn the separate /old receiver I get a thump to the sub that I didn't have before when i had my avr3300 hooked up.
This thread is locked
