read the guide you need a "Fixed" speed2.exe and to use the program provided. Works for me, thats why I posted the image. If you guys get stuck let me know, I'll help if I can.
Remeber this is not an Official patch do it at your own risk.
Step 1 install the game like regular.
Step 2 make sure it works and is ok.
Step 3 download the file in the post over there just click the word patches
"simply download the modified patches.ini "
Step 4 download this in a previous post in the same thread
http://www.prismaticorder.com/uniws.exe " That is the install program.
Step 5 get the no-cd "mod" pm if you want to know where.
step 6 replace the old speed2.exe with the new "Modded one"
step 7 run the program in step 4 and find the new file from step 6
step 8 follow the directions in the program, including setting a new ws res.
step 9 restart the game and select 640x480 for res that will be the widescreen you just made. It should work.
step 10 if you need help post here or pm me.
