Originally posted by CEB II
Mine suddenly started flashing "Loading" one evening a couple of weeks ago when it had been turned off in power-save mode. I hit the power button on the unit a few times and the flashing stopped. No further incidents and no apparent affect on other operations. Is there something else bad that is supposed to happen after it flashes "Loading"?
There are degress of "badness". Mine started a bit like yours. It crashed, then flashed "LOADING" whilst it was booting up and you are back up again. Then eventually it started doing this more often. At that point I returned it for a fix. When I got it back it would flash "LOADING" and never recover. It would just simply sit there flashing LOADING. It seems from reading the threads on this there are multiple causes of the problem (and they probably changed the wrong part).
Anyway that's the worse case in that it never boots up at all.
I would recommend waiting to see if the problem becomes much worse so that at least the repairers can see if the problem is fixed after making the repair.
I am pleased to see that JVC will fix this problem outside of the warranty period. I went out and bought a Panasonic ES-10 yesterday, since I presumed it was going to cost me almost as much to fix as to buy the Panny. The JVC sure had better PQ than the Panny, so I am looking forward to it being repaired.
