Yeah, I decided to play around with it while it was open and unseated and reseated all connections - still a no go. The weird thing is though, I tested underneath the board right where the molex connects to the board. I am not sure how to read the meter, but I had it set on 1000v AC and there are three spaces of numbers on there (not sure how that works out). I was getting the fluctuating with the highest reading being a 035 or something to that effect. However, due to my limited knowledge beyond the principles of what a circuit, this really tells me nothing, although it seems like it is not even getting enough power TO the board to start with (that is, unless the reading was normal). Again with my strange ideas, but it is not possible that the power cord itself is bad is there? The way that it is set up tells me that is probably nearly impossible (and yes I did try different outlets on the off chance that one just so happened to be going bad).
That being said, it is puzzling as there are NO visible signs that there is anything wrong with it at all - no burning, melting, discoloration or otherwise. This might actually be an interesting project for me to learn more about how it works and how to repair them. I mean, at this point, what is it going to hurt?
This power supply board does not look all that complicated - there are not too many capacitors and resistors, one of which, I am assuming is the culprit. From what I have read, it sounds like it is more likely that it is a capacitor (but I may be wrong). That being said, there are a couple of the larger cylinder capacitors that are not flat on the top - I have read about bulging, but the state at which they are in does not lend itself to me saying that they are bulging, more like just a little rounded.
Sooooo, if I could figure out which one is bad then I can just replace it and see if that works, but the problem is troubleshooting - I mean I have the tool, but do not really know where to start. I have found numerous fault-finding diagrams, but none for the layperson like me. If anyone knows how I can go about figuring out what the failed part is, that would be great. OR, if I really wanted practice, I suppose I could just replace them all! Not sure I am that gung-ho about it right now.
Mike
