AVS › AVS Forum › HDTV › HDTV Technical › Walmart US Digital STB Questions
Walmart US Digital STB Questions - Page 12
post #331 of 1562
Tried to get through to USDigital but couldn't. Are they still in business? Or have they gone under. Wanted to see if they might have a solution for my problem. My sound and video don't sync on ABC in Detroit. It only happens in primetime 8:00PM to 11:00 PM when watching HD programs. It later fixes itself in time for the evening news. I don't seem to have this problem with a Magnavox lcd with built in tuner.
post #332 of 1562
Looks like they're probably going out of business. They just filed for Chapter 7 bankruptcy. There's a thread about it over in HDTV Programming.
post #333 of 1562
Alright - i finally managed to snag one for 40 bucks
The walmart, close to my residence had two, and had them priced at $129 each - i had been checking frequently hoping that they would reduce the price as had a lot of other Walmarts around the country - no such luck
Then i found another walmart which had reduced the price to $40, but was all sold out. I went to the first walmart, bought it at full price, then took it over to the other walmart to return and rebuy it - the look on the customer service representative was priceless, when he returned it for $129 as per the receipt and then bought back for $40
Incase anyone is looking for these - i know there is one available at the walmart in south plainfield NJ and another one at Hamilton, NJ
I must say, it took me about 5 mins to get this puppy up and running, and it catches way more digital channels than my Dish 811. Great picture quality. Using it with deck mounted Silver Sensor.
post #334 of 1562
Any chance I could talk you into sending me the USDigital upgrade? I'll pay postage both ways. My box has a pretty bad audio clipping problem and I can't get any help from the manufacturer as they are out of business.
Tom Best
2903 Oak Park Drive
Austin, Texas 78704
Originally Posted by Larry Crowell View Post
What a coincidence. As I was writing my previous post, the promised USDigital update arrived in the form of a USB jumpdrive. The installation went as advertised. Well, guess what. There now is an actually useful antenna setup option in the setup menu. It provides a numerical signal strength from 0% to 100% (percent of what I have no idea) Also, the audio / video sync seems to have improved. There are also a number of other minor improvements, such as scanning through channel contents while still watching one channel. I think I'll keep it for $129.
post #335 of 1562
Larry posted that back in April. I can't speak for him, but my upgrade (in March) was accompanied by an envelope for sending it back to USDTV. I wasn't supposed to keep it. I sent mine back because I didn't want them nagging me for it. If I had known that USDTV was going to go bankrupt in a few months, I might have kept it anyway so I could make a few bucks renting it out.
(just kidding)
post #336 of 1562
Are you sure they are out of business? I got mine 03-05-06 and mailed it back the next day. To my surprise, I opened the mailbox today and found the returned envelope with a "RETURNED FOR POSTAGE" stamp on the front. I mailed it over 5 months ago. What the heck is going on?
post #337 of 1562
I'm not sure I understand the previous post. If I understand correctly, it sounds like the Post Office had the USB stick for 5 months, not USDTV.
Additionally, I had a thought that maybe, just maybe, someone who has a lot of time on their hands and can read Chinese could check the Hisense websites and see if maybe they have a support page for the DB-2010. And if there is none, maybe Hisense could be contacted via email to see if they have (and would be willing to share) the DB 2010 update file.
post #338 of 1562
Sorry about the confusion. In my previous message I was referring to the software update. Yes, apparently the post office had the USB stick for 5 months. I have emailed USDTV, and they have yet to reply. But I figure after over 5 months, do they still expect to get it back?
post #339 of 1562
I would suggest that you hang on to it for awhile anyway. (see if they ask for it back) I tried to copy mine but the copy did not work (you know it works if you try update and it responds with already updated if it did not copy correctly -- nothing happens) it must have had a boot sector or something that I did not copy with the files (used linux to copy) or the memory stick I have is not compatible.
I think the software is proprietary with US Digital and not Hisense so they may not have the software. ??
post #340 of 1562
It's possible Hisense may have a generic version of the software or firmware or whatever you call it.
Sort of like when you flash the bios on a brand name computer (HP. Compaq, Dell, etc.) with one from the motherboard manufacturer. All the HP/Compaq/Dell logos are replaced with the motherboard manufacturer's logo, but it still works the same.
Anyway, it was just a thought.
post #341 of 1562
They did reply and asked if I sent it to the correct address. It seems like they have no idea what's going on.
post #342 of 1562
Originally Posted by mdviewer25 View Post
...My local PBS has an HD channel that only airs at night and 3 other subchannels that only air during the day. With the old software, all four subchannels would stay in the memory even if they were off the air. With this new update, I have to go to Adjust Antenna in order for it to find new channels. Does anyone know a way around this because it is annoying to have to keep doing this every time? I hope someone reads this and can post an answer to help.
It is Maryland Public Tv's problem. Their PSIP is not right; never has been. I get the same problem on my Dish 6000, and my two latest-firmware USDTV boxes. No such problems with WETA -- they send PSIP info for the subchannels even when they are not actively 'on the air'.
I have contacted MPT engineering several times. Each time I get ONE email reply saying they'll investigate. No response to follow up emails. Nothing ever changes. No one ever writes back.
post #343 of 1562
The upgrade files have to be on a bootable Linux USB stick. I made one today that does work (I get the 'already updated' message).
There are sites that explain making a bootable stick. I made mine using a Slax CD.
From the command prompt, 'fdisk' a usb stick that does not contain your firmware files. Delete the existing partitions. Create a Linux partition on it. Set the bootable flag. Write changes to the stick.
Now run 'mkfs' on the new stick device. Slax defaults to ext2.
Reboot and mount the source stick and a the Linux stick. (use 'tail -f /var/log/messages' to see where your USB drives show up as you plug them in)
Copy the files and directories from the source to the Linux stick. (I used Midnight Commander ('mc'), but any copy method should work.)
I used a 64 meg USB stick. $10 at Staples. Plenty of room.
_________________
What I want to figure out is how to convert a subscription USDTV reciever to a free-to-air box. The USB upgrade will not work for this.
post #344 of 1562
I just got this usdigital receiver a few days ago-was working great-until all of the sudden it won't display any video on my tv(via component cables)-only sound coming through. changed the component cables-no luck.Anyone know what problem is?
States comes with 1 year warranty-but # provided is out of service-any other way to get this fixed or refunded? It was a brand new item.
Version 2.5
Any help would be great-thanks...
post #345 of 1562
You may have pressed some buttons to put it in a different mode.
Press POWER
Press *RED* USDTV guide button
Press ASPECT
Press *RED* USDTV guide button again
Press 1 for regular (not hi-def) output
or
Press 5 for 1080i hi-def
2,3,4 are other choices for 480i, 480p, 720p
post #346 of 1562
ok-thanks-will give it a try
post #347 of 1562
I want to update my reciever. Could you send me the files for it?
madlobster@gmailcom
post #348 of 1562
Here is a response to a query I sent to USDTV several weeks ago. My question *was* addressed to USDTV VP Steve Morse.
We apologize for the delayed response. USDTV is currently undergoing restructuring and new ownership.
We need to see whether you are or were an existing customer to verify that the receiver is yours. If you live outside of our four service areas, you need to have a receiver that was FTA to begin with. If you purchased a subscription receiver from an unauthorized dealer, such as on E-Bay, you should return it for a refund.
In order to activate it for local, FTA service, you will need to have it set up with antenna. We need to have the UID and the serial number. The serial number is printed on the back side of the receiver and begins with 3 or 4 zeroes. The UID is displayed in system information. It begins with five or six zeroes.
Our customer service line was previously not staffed for about 30 days. However, we are now available:
877-438-8738
Week days until 8pm MOUNTAIN
Saturday until noon MOUNTAIN
Sincerely,
USDTV Customer Service
[Received Sept 1, 2006:]
We expect our new ownership to be finalized in the middle of this month (September). The new ownership will decide whether to continue the previous service of converting service boxes to FTA boxes and how much it will cost.
We recommend you contact us after the 11th to inquire about this possible service.
Sincerely,
post #349 of 1562
R these boxes still avaliable to buy?
post #350 of 1562
Yeah, they're still around. I bought one in Williston, Vermont on Aug 19 for $129 but there were only 3 left in that store. They are definitely getting scarce.
I emailed the company about a week ago and haven't had a reply re: getting a firware upgrade.
Does anyone have still have a USB upgrade key in their posession? I would be willing to pay all costs.
For the most part, my box is working just fine, but the one issue I have is that it freezes up on autoscan on one strong channel. I just manually add all the channels. Bu the strong one can't be detected.
I'm in Canada and I bet USdigital wouldn't bother sending me the firmware upgrade even if they weren't facing financail difficulties....
Can anyone help me out? Andrew
post #351 of 1562
Paula,
I would like to update firmware but when I call US digital - they are in bankruptsy
protection - nothing coming out of there for now or maybe never.
Can you send the file to me to create the usb key ..thanks
post #352 of 1562
Andyman,
I have the same problem, I live in the Toronto area and local channel 9 cfto
has this issue. It is a problem with the psip - apparently CFTO has a problem with
a rotating psip - I don't quite understand but for a few weeksin early july cfto worked great.
post #353 of 1562
Thanks for confirming that you've had issues getting 40 as well. I live in Toronto too - southern Etobicoke).
I get everything from Buffalo with an external UHF antenna except WB. I guess I'll try scanning again for CTV again sometime in the future. I'm amazed how well digital signals look coming across the lake. Forget old analog and snow.
Still wondering if anyone has the USB firmware key?
Was ready to buy the Samsung while in the States. but fairly happy with the USDigital...
post #354 of 1562
I think the US Digital is definitely a better product than my Samsung. It switches channels faster, the guide works better, and it does a better job of zooming in than my Samsung T-451. It also doesn't have those annoying random reboots that the Samsung has.
The only thing good about the Samsung are buttons on the front if you happen to lose the remote.
Too bad Samsung isn't the one filing for bankruptcy, I hate their products, and could do without them. And I hope US Digital can get through this.
post #355 of 1562
And it doesn't have those annoying gray bars.
post #356 of 1562
I have had the usdigital box for just over a year now, with no major problems.
Had to hold the power button down to reset it a few times.
But now however the thing just stoped working, the power and signal lights just keep blinking, anyone had this before?
I have tried unplugging with the power button held and nothing.
Any sugjestions?
post #357 of 1562
I just got one of the locked US digital tuners from eBay. When turning on, it shows the USD logo screen in yellow. Does anyone know if by flashing the firmware will unlock it for me to use it as an over the air tuner?
post #358 of 1562
It will not even notice the USB thingy.
However, it will work as an OTA receiver with some limitations. That screaming yellow color not being the least of them.
post #359 of 1562
My receiver when turned on goes through the antenna scanning process then asks for activation by US Digital. It won't allow me to do anything else. Is there anyway I can unlock it?
post #360 of 1562
The scanning on these boxes can get weird.
Mine locks up on a particular channel so I manually add them.
Still looking for a firmware upgrade.
USDTV has been silent to my requests.
  Back to Forum: HDTV Technical
