Originally posted by Cheezmo
I would try seeing if MATR_CBG and MATR_CRG can be used to get the green color decoding balanced (NOT for any grayscale issues). I would use the "Gamma On" parameter to isolate green instead of using a filter.
I did this and man all my colors are right on now. Thanks Cheezmo. What I did in order to make this work perfectly was tricky. I isolated each color using Gamma On setting, quit SM and when to Cinema mode to see how each color looked until it looked perfect. I ended up with the following settings:
Contrast: 90
Brightness: 40
Color: 50
Sharpness: 0
My only complaint now is black level of course and getting an ISF professional to calibrate gray scale.
It's looking great though. Be careful on setting 7 on Gamma On as Cheezmo indicated. I believe setting 3 isolates blue, 4 is green and 6 is red.
