The ballast is about as easy as the lamp. Once you take the lamp out, the ballast lifts right out. The screws that hold the lamp in, hold the ballast in too. Worst thing is that you need to invest the $80 to find out if that is it. Since the set is coming on, and then going off, it seems like the ballast should be a high probability item.
The partstore.com was very good about taking my ballast back. (I have an RMA and the part is on its way back to to them... hopefully the rest of the process will be smooth).
