Originally Posted by kuharious
Anyway I wanted to get you smarter guys take on what I can do to increase my signal strengths. Amp, better antenna, or both?
BTW hardware is a cheap handmade antenna in the attic split between a HDHomerun to the computers and to the main living room TV. I would like my other TVs(3 others) off the antenna if possible.
Without knowing what you are using for an antenna or where you are located, I can't really recommend changes to it. Try TVfool.com to see a directional plot of what can be received at your address. You might be able to pick a bit more than you list.
As for the amp, that is used to compensate for the losses in the coax. You will need to calculate those losses and then get an amp that matches that loss, a little extra is OK, and insert it close to the antenna. As a rule of thumb each 100ft of RG6 adds 3db loss (50%) but more importantly each splitter also adds this much. Furthermore when you split the cable, you will want to try and keep the length of the two split cables close to the same. If this becomes too complex given that you want to connect, sounds like a total of 5 devices, then you might want to look at a distribution amp.
..The good ones are when they go on for minutes about stuff then don't leave any contact info..
