Originally posted by chief17
one more question... i get wbtv-dt and wbtv-sd... i assume the sd stands for standard definition, but what is dt? and how do i know if the show i am watchiong is in hd or not? I am watching the handler on cbs right now.. the picture looks great, but i don't think it is hd.
Digital Television, I guess. They make-up those names, and there doesn't seem to be a standard (some networks use a dash, others don't). For CBS, titantv.com is usually accurate, but Charles is right that decisions at the local station can mean you see a red "HD" on titan and you get SD on your set.
now my signal seems to come and go quite a bit... i am having a hard time getting a constant picture without moving the antenna every 30 seconds. it seems to go from 60% to 20% instantly. are there any secrets to finding a good spot with constant reception?
from the antennaweb site i got a 'red' for channel 23. is that good or bad?
Yellow would be better. Red, for me, means on the roof to get a signal through thick and thin. Jumping around, again for me, usually means interferance, multipath, or possibly overdriving your receiver. I don't know about the specific antenna you bought, but if it handles both VHF and UHF that means it's picking up and amplifying the FM band. If it has an FM trap, make sure it's active. If interferance is from other TV stations or multipath, and you don't want to buy more hardware, you just need to try more positions. You might need to do something drastic (how much coax did you get?). If you are overdriving (how many dB is the amp on that antenna, and what's it's noise rating), then you might attenuate. If you have a long length of coax, that would act as an attenuator, and you'd be ready to climb if it didn't work! It might seem like I plug Radio Shack a lot, but that and Slayton Electronics are the only local places I go for geek stuff. Anyway, they (RS) have a UHF-only yagi for $20 (a yagi is highly directional, so if interferance is a problem, it will have to be UHF interferance from Kings Mountain, or something between you and Kings Mountain). Good luck!!
--Dale--
