AVS › AVS Forum › Audio › Home Theater In A Box › A Sony Yamaha Christmas
post #1 of 2
Here was Christmas at my house:
SONY 30" Widescreen FD Trinitron® WEGA® HDTV
(Model No. KD-30XS955)
http://www.sonystyle.com/intershopro.../KD30XS955.jpg
Specifications
Power Requirements
• AC 120V 60Hz
Inputs and Outputs
• Component Video Input (Y/PB/PR): 2 Rear
• Composite Input: 1 Front/3 Rear
• S-Video Input: (With Detection): 1 Front/2 Rear
• Control S: 1 Rear
• HDMI: 1 rear
Tuner
• 8 VSB
• ATSC, NTSC
• Clear QAM
• Digital Cable Ready
Audio
• TruSurround® SRS® Audio (7.5 watts x 2 w/ 15 watt subwoofer)
• Steady Sound® Automatic Volume Control With BBE® Audio Effect
• Auto Mute Tuner
• Auto SAP
• Audio Output (Variable/Fixed)
Video
• Dynamic Focus™ Circuitry
• Dynamic Picture™ Circuitry
• Trinitone® Color Temperature
• ClearEdge VM™ (Wideband Velocity Modulation Scanning)
• Vertical Aperture Compensation
• Vertical Center Adjustment
• 3D Digital Comb Filter
• Wide Modes: (Normal/Full/Zoom/Wide Zoom)
• Auto Pedestal Clamp
• Auto White Balance
• High Voltage Regulator
• HD Detailer™ Wideband Video Amplifier
• NTSC Color System
• ID1 Detection
• Magnetic Quadruple Pole
• Tilt Correction
• Vertical Correction
• Vertical Size Adjustment
• 1080i
Convenience
• Auto Channel Program
• Caption Vision (CC)
• Channel Fix
• Channel Skip/Add
• Video Label
• V Chip Parental Control
• Speed Surf™ Channel Selection
• Sleep Timer Function
• Tilt Correction
• Program Palette™ (Vivid/Movie/Standard/Sports) presets
• On Screen Display (English/Spanish/French)
• Channel Jump
• Front Button Menu Control
• Favorite Channel
• Clock/Timer Two Event
• Antenna Level for DTV
• PSIP Program Information
• DTV Auto Add
Dimensions (WxHxD)
• 35 3/8" x 23 3/4" x 22 1/4" (898 x 604 x 564.5mm)
Weight
• 154 lbs. (69.8kg)
( ^ Price Paid: $1099.99)
YAMAHA YHT-750
http://www.yamaha.com/yec/products/p...yht750main.jpg
Specifications
6.1 Channel A/V Home Theater Receiver
(Model No. HTR-55740SL)
• 6.1 Channel A/V Home Theater Receiver
• 730 Total Watt Output
• High Power Discrete Amplification 130W X 1 (subwoofer)
• High Power Discrete Amplification 100W x 6 (main, surround, and center)
• DTS-ES Discrete, Dolby Digital EX, Dolby ProLogic IIx Decoding
• Yamaha Original 32-bit Cinema-DSP Processing
• 29 Cinema-DSP Surround Modes
• 192kHz/24-bit DAC
• 2 audio A/V inputs
• 4 video A/V inputs
• 2 component video inputs
• 2 optical digital inputs
• 1 component video output
• 1 coaxial digital input
• Front Panel A/V Input
Voice Matched Speakers
(Model No.: NS-AP3500SL)
• 2 Front Speakers w/ 3" High Compliance Pulp Cone Woofers and 1/2" Balanced Dome Tweeters
• 3 Surround Speakers w/ 2.5" Pulp Cone Woofers and 1/2" Balanced Dome Tweeters
• 1 Center Channel Speaker w/ Dual 2.5" Pulp Cone Woofers and 1/2" Balanced Dome Tweeter
• 2-Way Acoustic Suspension
• Magnetically Shielded
• 90Hz to 50kHz Frequency Range
Powered Subwoofer
(Model No. YST-SW030SL)
• High Power 130 Watt Advanced YST Subwoofer
• QD Bass Technology
• 8" Spruce Cone Driver
• Frequency Response: 28Hz to 200Hz
5-Disc DVD Audio / DVD Video Changer
(Model No. DV-C6660SL)
• Progressive Scan
• Yamaha Play Exchange Technology
• 5-Disc Carousel
• Plays DVD-Video/CD/VCD
• CD-R and CD-RW Playback Compatibility
• MP3 Playback Compatibility
Digital AM/FM Tuner
• 40 station presets
General Features
• Digital ToP-ART (Total Purity Audio Reproduction Technology) incorporates 3 key technologies to produce superior sound quality
• HDTV-compatible component video output frequency response range of 5Hz-60MHz ensures compatibility with HDTV monitors and HDTVs
• High current amplification receiver uses superior components to achieve current power with low impedance from input to output resulting in superb audio performance
• High-performance 192kHz/24-bit digital-to-analog conversion for all channels
• Subwoofer preamp outputs with 9-band selectable cross-over lets you customize efficiency and performance for the best bass response
• Consumer Reports No. 1 Choice - HBiTs (11/04)
( ^ Price Paid: $449.99)
I'm happy. :)
post #2 of 2
Sweet, Hows it look and sound
  Back to Forum: Home Theater In A Box
This thread is locked
