AVS › AVS Forum › Other Areas of Interest › What's Your System Configuration › A Modest Building Block
post #1 of 2
Having ignored the tech advances for the past 10 years, this setup will help smooth the learning curve and allow for upgrades in a few increments.
Panasonic Th-37PD25U
I exchanged the Phillips widescreen CRT for the Panny plasma. It arrives on 12/31.
Pioneer VSX-1014TX
This will do for a few of years.
Athena 5.1 System & ACI Force Subwoofer
The Force is great, and the Athena will be substantially upgraded after the plasma is in place. A 2nd force sub is planned.
Pioneer DV-578A
Since I have a fair selection of Asian DVDs, the Pioneer has been modded for code free play by JVB Digital. A second higher quality DVD player for will be added to go with the plasma.
Final config scheduled for next Dec.
post #2 of 2
I decided to upgrade directly to a Panosonic TH-37PD25U which should be in place tomorrow.
This thread is locked
