Originally posted by sharms
I was wondering where you got all your fabric from (did you order it online or buy it locally) Is the stuff expensive.
Lastly you put in some kind of batting just wondering where you purchased it and what kind it is.
It is all GOM about $1,100 bucks, bought it on-line.
The bottom half of the wall is JM linocoustic the top is a 1" loft Poly Batten from Joann's fabric. The bottom of the soffit and the entire area behind the screen and speaker walls are also JM linocoustic.
