AVS › AVS Forum › HDTV › HDTV Recorders › JVC Dishnetwork D-VHS Discontinued?
post #1 of 2
Just wondering..
I was up at the Dishnetwork site a couple of day's ago and noticed that they are not offering the JVC D-VHS anymore. Does that mean that it's discontinued??
Gees, I just got the thing a couple of months ago!
-Wynn
post #2 of 2
Well to answer your question first. Yes, I have noticed a couple of times on movies that there is the intermitent blackouts that you experienced. I just chalked it up to some irregularities in the tape (which i thought was odd,being it DVHS and such). I actually don't use the DVHS tapes that much since I usually record stuff off my local stations and since it's considered analog off the DMS-100 I can't record digitaly anyway's. I have used it to record stuff off of the movie channels etc and it works great. I liked the idea that I could record the movies on the DVHS tape and keep the superior quality and keep the ac-3 dolby soundtrack (if it was sent that way).
I hope they continue to make tapes for it. Or should I just sell it on ebay and cut my losses??
Hope that helps
Wynn
  Back to Forum: HDTV Recorders
This thread is locked
