AVS › AVS Forum › HDTV › HDTV Recorders › PVHD1000: 5nF
PVHD1000: 5nF
post #1 of 10
Tonight I discovered I had a "5nF" displayed from an attempt to record a program. The recording was blank. It appeared that my DST50 was failing to send a digital signal to the recorder after working fine for months. Without switching off and on I put the recorder in playback mode from the DST50 on screen and then it worked. Then recorded a whole movie just fine from the local control.
Has anyone seen this error message 5nF? I now assume it indicates no digital signal in recorder's 1394 input but I have just never seen it before.
Don Landis
NEW! Home Theater Pics at:www.scubatech.com updated 5/11/00
post #2 of 10
Don- are you sure that's not "5C" coming up on the screen? http://www.avsforum.com/ubb/wink.gif
post #3 of 10
It was 5nF, not 5C. At first I thought it might have something to do with that but I was able to reset the tuner and correct the problem.
Don Landis
post #4 of 10
"Paranoia strikes deep; into your dreams it will creep..."
post #5 of 10
Doesn't anyone use their manuals any more?
Page 37.
"INPUT SIGNAL NOT FOUND" is displayed on the screen and/or "SnF" is displayed in the Multi Function Display during digital recording...
CORRECTION
* Make sure the IEEE 1394 cable is properly connected.
* Turn the Set Top Box* power off and then on again
*When using the Set Top Box TU-DST50 only.
Anyway, that is what is in the manual about it.
Steve Martin
The Widescreen Movie Center
post #6 of 10
Yes, Steve, I did look specifically on that page, infact scanned the whole manual looking for it, but didn't see it in my haste! I was not looking for "INPUT SiGNAL NOT FOUND but you're right, it's there in the fine print. S (not 5 which is what it looked like on my panel) But had I taken more time I would have figured it out. As I said resetting the STB did the trick!
Don Landis
post #7 of 10
I didn't mean to sound harsh. I actually intended a smiley but forgot it. I saw that same message (SnF) once several months ago (and freaked accordingly) but did find the thing in the manual which is the reason I remembered it. Nice to know the solution you came up with is the recommended one http://www.avsforum.com/ubb/smile.gif
Steve Martin
post #8 of 10
Steve, I deserved it! What goes around comes around and I'm always accusing others of not reading the manual. I just overlooked it that evening and I didn't think you were harsh at all. Heck, with a name like Steve Martin, well, the name itself brings smiles!
Don Landis
post #9 of 10
Well then...
EXCUUUUUUUUUSE MEEEEEEEEEEEEEE!!
Steve Martin
post #10 of 10
I've seen the "5nF" display when attempting to dub from one unit to another. This makes dubbing very tedious since it is a blind operation. I may need to reconnect the STB and reposition the tapes when this happens, if I happen to be dubbing within the tape rather than at the beginning.
I hope those friends of mine get their cuts editor for HD mpeg working.
  Back to Forum: HDTV Recorders
This thread is locked
