AVS › AVS Forum › Video Components › Cable, Digital Cable - Non-HDTV › D* Local Channels question
post #1 of 3
Ok I have regular cable now through Charter and I live in Parkersburg WV which is an hour north of Charleston. Parkersburg has a local NBC station which D* doesnt offer but I could easily get it via antenna. There is also another NBC station I get through cable and its in Charlestion, and my other ABC,CBS and Fox are all based out of Charleston which I get though Charter.
My question is.... when on D*'s website seeing if they have my local channels(Parkersburg zip), they say they have none. When I put in a Charleston zip they say they offer all the local networks (the same ones I get through Charter)
So will D* be able to give me the Charleston network stations that Ive always had in Parkersburg?
post #2 of 3
You will probably have to get waivers to receive the networks...there is no harm in calling them and speaking to a rep. If the answer was yes, werent you going to get it anyway? If the answer is no, the you know either way.
post #3 of 3
I'm not positive, but this is what works with me. Whatever shows up when you put your zip in http://www.directv.com/DTVAPP/LocalChannelsAction.do is what they can give you, or else you need an antenna or may qualify for DNS which I think means you get the East and West coast feeds of the main local channels. This is the site for DNS eligibility http://directvdnseligibility.decisio...dressEntry.asp but I think the government is making changes to DNS eligibility and their site will show these in early 05 http://www.directv.com/see/landing/dns.html
  Back to Forum: Cable, Digital Cable - Non-HDTV
This thread is locked
