AVS › AVS Forum › HDTV › HDTV Recorders › RECORDING HDTV
RECORDING HDTV
post #1 of 3
IT THERE ANY WAY TO RECORD HDTV W/O THE DISH 5000 AND PVR? I HAVE DIRECT TV AND I WANT TO RECORD SOME OF THE BROADCASTS, EVEN IF I CAN ONLY RECORD OTA. ANY IDEAS ?
post #2 of 3
If you check out the HTPC forum you will find a good solution to store the video recorded from the hi-pix and WinTV-HD onto Camcorder DV tapes (forgot what they are actually called now).
STOP DVI/HDCP!!!!!
post #3 of 3
Chap:
The camcorder backup tools are called DVSpoof. This approach works.
-yogaman
  Back to Forum: HDTV Recorders
This thread is locked
