AVS › AVS Forum › HDTV › HDTV Recorders › Panny TU-DST50W Question...
post #1 of 6
Is there a way to set the Panny TU-DST50W to DTV channel 3
without the remote? I just bought my unit off of eBay and it did not include the remote. I've ordered a new remote from Panasonic but it won't arrive before my DISH 5000/Modulator
setup is installed on Monday. I looked on Remote Central for
TU-DST50W CCFs for my Pronto remote but could not find any.
STOP DVI/HDCP; Boycott JVC
post #2 of 6
You can use the buttons under the front left panel to go into the menu, delete all channels by doing a auto search with the antenna disconnected, then reconnect antenna, and manually add just ch 3.
"Better living thru modern, expensive electronics devices"
tm
post #3 of 6
Rick,
Another forum member sent me a ccf for the DST50 a few days ago, it's simple but works well. I'll e-mail it to you.
Nick
post #4 of 6
How much was the remote?
Only in America.....Don King
post #5 of 6
eighty one dollars plus shipping. from 1-800-remotes
Nice to have.
The PVHD 1000 remote was about$52
RJW
[This message has been edited by wezar (edited 07-24-2001).]
post #6 of 6
Most setup, tuning, etc. can be done from the front panel. As I recall, though, there is no way to change aspect ratios without a remote! (And of course, no way to access the hidden service menu.) http://www.avsforum.com/ubb/wink.gif
My first 50 was purchased "sans remote." I ordered mine directly from Panasonic (don't remember exactly how much, but it seems like $59.95 sticks in my mind).
At first I was going to pass up the original remote and go straight to the universal route, but am glad I didn't.
Peter
  Back to Forum: HDTV Recorders
This thread is locked
