AVS › AVS Forum › HDTV › HDTV Recorders › hd recording setup
hd recording setup
post #1 of 3
is there a search word anyone can recommend or someone post a link to the setup and hardware requirements for recording hd on my pc?
Kipp
IS THAT A REMOTE CONTROL IN YOUR POCKET OR ARE YOU JUST HAPPY TO SEE HDTV?
post #2 of 3
try AccessDTV, HiPix, ADTV, and record AND HDTV.
I would also try these in the HTPC forum as it is very active and a lot of those guys are into HDTV as well.
(preview - you basically have two options - Hipix or ADTV)
Good Luck.
ebr
My Theater
post #3 of 3
Thank you for the information.
Kipp
  Back to Forum: HDTV Recorders
This thread is locked
