AVS › AVS Forum › HDTV › HDTV Recorders › Where to buy firewire connector?
post #1 of 4
Looking for sources for 1394 for pvhd1000. Locally all i can find are 4pin to 6pin.
post #2 of 4
That is exactly all you need... 4-pin firewire... just like
you'd use for your computer.
I bought a "generic" 4-pin 1 meter firewire at Micro Center
for about $7, opting to ignore the higher-priced ($14)
version from Monster.
Works perfectly with my DST50 <-> PV-HD1000.
post #3 of 4
I think the 'Bra is asking where to get a 4pin to 4pin firewire cable. I've been buying most of my cables from this place recently: www.pccables.com
They're cables are high quality and are very reasonably priced.
Jeff
post #4 of 4
I bought mine from here and was very satisfied. They are in the Orlando area.
http://accessories4less.com/advscrip...st.asp?area=13
George Waters
[This message has been edited by waters (edited 07-26-2001).]
  Back to Forum: HDTV Recorders
This thread is locked
