AVS › AVS Forum › HDTV › HDTV Recorders › Digital channel converter
post #1 of 10
I came across a black box on the net that takes an OTA signal, demodulates it, does base band processing, and then remodulates it into a 44.0 MHz I.F. (not R.F.) output. I wondered if this would have any applications in the HDTV Recording Forum. I know R.F. stands for radio frequency, but what does I.F. stand for?
Dave
post #2 of 10
Dave,
IF stands for Intermediate Frequency.
I cannot see how this would fit into the Dish5000-Panny combo scheme for HD recording.
Chazz
post #3 of 10
If it's cheap and 8VSB it might be useful for experimenting. 44mhz isn't that far from chan 3. Where did you see it?
-Roger
Analog -- Always out of adjustment.
Digital -- Always one more bug.
post #4 of 10
I am searching for the web site. It does have a BNC output before the signal is remodulated. Would this signal be recordable by the PV-HD1000?
post #5 of 10
No, the HD1000 only accepts firewire (2 twisted pairs).
That BNC might be SDI (serial digital interface).
-Roger
post #6 of 10
This is similar to another post regarding ATSC and Echostar.
The signal off the satellite is not ATSC It is in a DVB packet and probably has all kinds of non-standard modifications by Echostar.
I think what you are thinking is hetrodyne the raw satallite signal to 44mhz. That won't work. All you will get is the DVB stream on a 44mhz carrier. Plus the modulation is most likely 64 QAM.
post #7 of 10
Gridleak,
I saw it at There is also a pdf. file under application notes.
Dave
post #8 of 10
Thanks Dave,
Your fingers schmooshed it a little. It's http://www.ktechtelecom.com/remod.html. Broadcast stuff. Might be a little pricey.
-Roger
post #9 of 10
Originally posted by gridleak:
Thanks Dave,
It's a finger-smooching evening...! I think a unwanted period is there, should be: http://www.ktechtelecom.com/remod.html
"You can't argue with a confident man"
- Napoleon Wilson, Assault on Precinct 13
[This message has been edited by HiDefGuy (edited 08-28-2001).]
post #10 of 10
Dave and I were working on a new comedy routine and thought we would polish it up here at the forum.
BTW, HiDefGuy, you misspelled shmoooshing.
-Roger
  Back to Forum: HDTV Recorders
This thread is locked
