AVS › AVS Forum › HDTV › HDTV Recorders › HipIx Setup
HipIx Setup
post #1 of 6
Can someone walk me through a HiPix set-up?
RCA Ultimate TV
Sony Tivo
Phillips Tivo
post #2 of 6
Larry,
What do you need to know?
Kei Clark
Digital Connection
post #3 of 6
1. Recommended drive size?
2. Required cpu speed?
3. Hi-Pix card or DTV ACcess card? which emulates a tivo better?
4. Are there (or have there been) any problems using this system?
RCA Ultimate TV
Sony Tivo
Phillips Tivo
post #4 of 6
Larry,
Hope this helps, as answers are subjective.
1. Just remeber the required disk space for recording is approx. 8.7GB per hour.
2. Could be lower, but recommend all things considered, 500+ MHz.
3. AccessDTV emulates TiVO better, but for this you'll need the subscription guide service.
4. Some, but now most are minor bugs. Just make sure you have signal by checking www.titantv.com for broadcasters in your area. If you're using rear projection CRT TV in the mix, highly recommend using the HiPix.
Kei Clark
Digital Connection
post #5 of 6
Hi,
Why is the HiPix better for this?
post #6 of 6
I think it has something to do with the voltage output of the HiPix card being closer to the "correct" levels. Or adjustable to be so. I'm still trying to decide which card to get myself. Or wait for the next generation....
Mark
  Back to Forum: HDTV Recorders
This thread is locked
