AVS › AVS Forum › HDTV › HDTV Recorders › Mitsubishi HS-HD2000U on Mits web site
post #1 of 22
http://www.mitsubishi-tv.com/PDFs/dvcrspecs.pdf
Link to HS-HD2000U. Looks like it is a nice piece. Now if it only worked with TU-DST50.
RJW
post #2 of 22
It might, working on this as we speak.
"Better living thru modern, expensive electronics devices"
tm
post #3 of 22
Go Ken, say its true. Tell us that the DST 50/51 is compatible with the Mits D-VHS recorder. Please say its true. Then we finally have an alternative to the over-priced PV HD-1000 recorder. It certainly would send shock waves to those greedy sellers on e-Bay.
post #4 of 22
Notice that this unit does not have any Component Video outputs. It only have composite, S-Video, RF Antenna out. Apparently, and HD is output only via the firewire port.
So, this is not an option for me & my Sampo.
post #5 of 22
What is the purpose for the HD2000U?
-It doesn't have a HDTV tuner
-It has only firewire input and output for HD (apparently). I don't believe any recent STB's have this connection.
-Only 480 line video, so it's not HD at all
Am I missing something? I can only believe this is for some special Mits product line.
Mark
post #6 of 22
Today...9/13/01...the purpose of this new HD VCR is to work with the new Mits and Sony HDTV's that are coming out with an ATSC OTA HD tuner built in.
It will not work with the existing population of HDTV's that have no Firewire connections with the POSSIBLE exception of the older, no longer being made, Panasonic OTA HD STB's.
Lee
post #7 of 22
What about the "480-Line 3D Y/C comb filter", as mmburke mentioned? I saw that too, but I wasn't sure if it was some feature related to composite/S-Video, or does it only record 480 lines of resolution?
post #8 of 22
It'll record any DTCP encrypted digital video that it can receive onto D-VHS tape. It cannot itself decode that video at all--it can only regurgitate it on command for something smarter downstream to decode and display. Right now, as Lee pointed out, it can be connected to the single Sony set that's on sale now, the KD-34XBR2, a 34" direct-view; in the near future, there will be a couple of other Sony sets and some Mitsubishi sets with integrated tuners and 1394/DTCP connectors that it can be connected to (according to Gary Merson's article in the latest Perfect Vision, a couple of the Mitsubishis should ship this month and next, with higher end stuff coming out early next year). It could use the ATSC tuners in those sets to record OTA HD. It could possibly also record DISH Network stuff tuned through an HD "upgraded" 5000 or 5022 receiver connected to that ATSC tuner (I think--didn't these pre-6000 HD upgradeable receivers require that the set have a tuner? The upgrade must encoded the video into an 8 VSB modulated ATSC channel--it enters the STB as MPEG-2 anyway--which would give the set an MPEG-2 TS stream to send over 1394/DTCP). It could not record the HD analog component video that the DISH 6000 and DIRECTV Plus STBs output.
When there are STBs with 1394/DTCP connections, it will be able to record from them (except, of course, pay-per-view, which will almost certainly be marked "Copy Never", since that's the only broadcast material the DTCP Adopter's Agreement allows to be marked that way). Echostar has stated that it is putting these on an upcoming DISH Network STB.
-- Mike Scott
[This message has been edited by michaeltscott (edited 09-13-2001).]
post #9 of 22
For the S-VHS recording and playback, I'm sure.
-- Mike Scott
post #10 of 22
I'm all set as I have a KD-34XBR2. However I'm not sure I can use the Mits to record one HD program while I watch another HD channel. If it can't then that's a serious disadvantage. Starting this Fall we'll finally have some HD component going head-to-head.
Garrett
post #11 of 22
Garrett,
As pointed out, there is no tuner in the Mits HD VCR so you will only be able to record either what you are watching or time shifting of programming for future use.
Lee
post #12 of 22
The new Mits Digital VCR will be a perfect match for my Mits WT-46807 with the Promise Module installed. And since I already have a Mits HD-5, I will be able to view a HD source while recording another HD source.
Bruce.in.Cary
post #13 of 22
I asked this question in another thread, and no one seemed to know....so I'll ask again.
With the advent of this Mits VCR, does anyone know of plans by Hughes/Mits/Toshiba to release updated versions of their respective STBs (all made by Hughes) to include the 1394/DTCP interface? All of the current STBs were first ready to ship in mid-2000 (if I remember correctly) but were delayed by the APG problems until late 2000/early 2001.
Well, it's been a year....and it seems like time is ripe for Hughes to bring out an updated box.
Any news anywhere? Laser Land here in the South Bay has no knowledge of this, and suggested that announcements might be made at the CEA show in January.
post #14 of 22
Bruce, that will probably be the only way to handle two HD programs at the same time. Like you, I also have an alternate STB, a retired Samsung SIR-T150. It can be used to handle the input being viewed. Though not an elegant solution it would be quite workable.
Garrett
post #15 of 22
According to the Mits rep I spoke with in July of this year, there will be NO 1394 STB coming from Mits in the year 2002.
The only company who has seemed to indicate that they might have a 1394 and a DVI HD STB coming in 2002 is Echostar (dish network).
Lee
post #16 of 22
Any word yet on whether this unit will work with a Panasonic TU-DST50/51 STB???
Dave Harper
Harper Home Theater Systems
post #17 of 22
Dave,
No word yet. But again, it might.
tm
post #18 of 22
Thanks Ken, I'll be waiting (im-)patientlyhttp://www.avsforum.com/ubb/wink.gif!!!
Dave Harper
"Dr. Evil Strikes Again!!!"
post #19 of 22
What system is the DST50 for? I haven't heard of it before.
-- jas
post #20 of 22
The TU-DST50/51 are the defunct Panasonic OTA-only HD receiver model.
"You can't argue with a confident man"
- Napoleon Wilson, Assault on Precinct 13
post #21 of 22
Has anyone seen this unit in stores yet? Also will it work with the Panny combo?
RJW
[This message has been edited by wezar (edited 10-11-2001).]
post #22 of 22
Still working, visualize your desktop with the cursor in motion, like the hourglass.
Sorry for any angst caused by the delay, I was hoping to have an answer by now.
tm
  Back to Forum: HDTV Recorders
This thread is locked
