AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Intruding "audio" intro
post #1 of 2
I've been visiting you guys for quite a while now, but I find your new intro to be intruding. Only the audio is intruding. It's a bit loud and long. If you want to keep the audio, maybe you could lower the volume a little and have a button that will disable the audio "immediately." I tried to "skip" the intro, but that feature is not very responsive.
Instead of normally typing avsforum.com in Internet Explorer, now I skip over the front and just go straight to the forums.
All of the above was just a suggestion.
MM
post #2 of 2
Don't worry MM, It will not be up their for long. http://www.avsforum.com/ubb/smile.gif This is an opening we had a long time ago and, well, just wanted to have some fun with it again. http://www.avsforum.com/ubb/smile.gif
David Bott
It's A World Of Entertainment...Experience It!
AV Science/AVS Forum Admin
http://www.avscience.com
The Nate Home Theater
  Back to Forum: Forum Operations Center
This thread is locked
