AVS › AVS Forum › AVS Forum Information › Forum Operations Center › Editing avatar image ?!!
post #1 of 4
I've tried for two days and several tries to edit the original image. After I go through all the hoops, the image looks good in the "sucessfuly uploaded avitar page" but when I go to profile page, the custom tag gives me the same old image. Same for the test page.
How can I get rid of the old image?
TIA,
Steve Hanna
Audioaficionado
post #2 of 4
You may be seeing a cache image if you see the old one after it tells you it uplaoded correctly. Also, if you origionall uploaded a JPG and now are uploading a GIF, the JPG will be the only one that shows as it is the first choice of the system at this time.
David Bott
It's A World Of Entertainment...Experience It!
AV Science/AVS Forum Admin
http://www.avscience.com
http://www.avsforum.com
The Nate Home Theater
post #3 of 4
How can the image be deleted? I already tried to delete the cookies.
TIA,
Steve Hanna
Audioaficionado
post #4 of 4
Image can not be deleated, you can simply choose to stop using it in your profile. If you need it removed becuase of the above issue, e-mail me and left me know. Don't forget to give your your user name in the e-mail.
David Bott
  Back to Forum: Forum Operations Center
This thread is locked
