Originally Posted by
Wendell R. Breland
Terry,
After all these years it looks like I will be building a new Windows 8 (64 bit) computer soon and will lose the ability to use the MDP-130 in that computer. What PCIe ATSC/QAM tuner card would you recommend that will record .TS (.TP) files that are compatible with the MITs and VideoReDo?
64 eh?
See the debate:
http://www.ni.com/white-paper/5709/enQuote:
Wendell R. Breland
Thanks Terry & Dave. Man, this sounds like 3 steps backward, may have to get a motherboard with PCI slot(s) and get the 32 bit Windows 8 and continue using the MDP-130 (assuming it will run in xp mode under Windows 8).
For the majority of users their life won't be improved by going to 64 (really missing the tweak that allowed 2000/2000 server to access up to 16gig) the only advantage would be PC games that take over everything to run with more RAM and on high end video cards.
Vlad Theimpaler
I made the switch from WinXP x86 to Win7 x64 and had to drop MyHD (MDP-130) in the process. Now doing timeshifting via HDHR as tuners + CW_EPG for scheduling. It works great. I get .ts/.tp raw recordings and edit out commercials in VideoRedo. Had a few setup issues along the way, but they seem to be resolved (took about a month to get sorted out with the help of Terry and others), but everything's been great since the start of the fall TV season.
My long range plan is still to build that six-core AMD I mentioned earlier to test the difference between 32 and 64 myself, as the one disc I've acquired of 7 has both. At that time the second MyHD will go into a dedicated, nLight-ed version of XPPro, as I did for the replacement of the old broken down eMachine I had. The only reason for that is to improve performance of my videos, even though I was pleasantly surprised that the modest Sempron 145 handled the .mkv format with ease, no doubt that a multi-core will improve performance of my other tasks as well but for now, I'm sticking with the Sempron. When that time comes, I may need help here with the playlist manager, as the two boxes will be linked directly with a crossover ethernet cable. I have PLM and the others downloaded multiple times but still haven't used them yet, so will still be quite the noob with those MyHD utilities.
I'm scant now but in the new year (if we don't all die on 21-12-2012
) and I get the spare change, I'll be looking at buying one or two more MDP-130s on the used market for running in the den/home office, so I can watch TV as I do other things but first will come the actual construction of the new boxes, then checking the sales of monitors.
Wha?
no "buy it now" option? [gotta look to see if it shows up on ebay.ca]
Time left: 8h 43m 24s (Dec 02, 2012 16:28:46 PST)
Looks like I'm going to miss it, I'll be away from the keyboard at that time.
AHAAAAAAAAAAGG!!!!!
Shipping:
May not ship to Canada - Read item description or contact seller for details. |
Edited by browncoat - 12/2/12 at 9:02am
