Originally Posted by RalphArch
As Terry noted above the Guide with QAM channels is a crapshoot depending on your cable operator. Mine does pass a lot of the PSIP data (it does leave out the description of the program information). You have to have TitanTV aligned to the digital cable channel list and set up a recording once associating to the correct QAM channel to get recordings or watch now to work properly.
If yours don't work properly I would reset the association
You can also save the channel list to a file and edit the file and then load the file. You could fix all the channels at one time.
