Originally Posted by
Bhudda28
This may be a rookie question, but I just purchased a Dell 3007FPW 30in monitor.
I am using the pass through cable that came with the DVI daughter card along with my ATI x1900xt. I get the overlay display on my desktop, but when I change to HD mode the screen starts giving me a scrambled signal. Does anyone have any ideas on how I can configure my setup for HD mode display. The native resolution of the monitor is 2560 x 1600. Thanks for any suggestions
The My HD outputs the following resolutions:
720x480i (SDTV, rare)
720x480p (EDTV)
864x480 (16:9 EDTV Plasma)
800x600p (4:3, PC)
1024x768p (4:3, PC)
1280x720p (16:9 HDTV and PC, most compatible resolution)
1280x768 (16:9 PC and some plasmas)
1280x1024p (4:3 PC)
1360x768p (16:9 PC and Plasma/LCD-TV)
1440x1080i (4:3, Older CRT Monitors)
1920x1080i (16:9 HDTVs, some PC monitors may not support)
Native - Outputs native resolution of input per channel (similar to bypass)
If your display is compatible to any of the resolutons above, try them to see what works (or works best) on your display. The video processor used in a digital display, be it HDTV or PC biased, will determine how it works with the MyHD.
Note, the highest vertical frequency the MyHD can output is at 1360x768. If this does not work on the Dell, then check if it can handle 1280x720 (Many source devices cannot output 800p)
