Laserfan.......
after learning my lesson in '99 I only keep the OS
and what it needs to run on the boot(or internal)
drive...my setups for the MDP are all on the external drives
so if I only have to reinstall the OS, I only need to restore the shortcuts,or load playlists,channel lists and reservations
from the saved files but as I said earlier one set up is on a
refurb emachine (gateway product) and I'll never do that again because I got what the bastards call a medialess
machine. From 9:30pm Sunday night to 4:00am Monday
morn I was nursing a sick 'puter. Now I thought I had
wiped the hard drive clean (eventhough the utility I
was using reported only 76gig on what is 'posed to
be an 80gig drive) if it really had done that then emachines'
restore DVD should not have worked but it did,not only
that but there was no splash screen to redo the registration
instead it garnered info from the previous install and cut
the capacity of the drive to 50per cent of what it was.
So not having any utility to get rid of the Gateway crud,
I'm taking it into a shop on Wednesday to turn the drive
virgin again so I can downgrade to my own W2K pro plus
they are making me a nVidia driver CD for the motherboard,video and get Realtek AC97 for the audio
section. I could do that myself but I only have a 256K
connection to the 'net (yeah...choppy YouTube) and some
of those suckers are huge and I don't have the time.
Lesson learned, I'm sticking to "rolling my own" or if
I ever buy of-the-shelf again,make sure there are separate
disks for the OS,Optical and magnetic drives,mobos and
what's on them, for if there are any DIYers out there you know that you get disks for each part you buy, letting you choose what updates to d/l and when.
Like you I bought two MDPs and may buy one or two
more because checking the logs I never had a application
error or fault from the 130s its all system..aka
MICROSLOP!!!! & XP seems to have so much hidden crud
I'm staying with 2000 pro even when I have to go driver
hunting!
I'm sending this on my 'spare' reliable,pure Intel P3
and watching TV at the same time with the second
130.
To repeat...Lesson learned.
hunting!
130.
