AVS › AVS Forum › Other Areas of Interest › Movies, Concerts, and Music Discussion › Help! Crouching Tiger locks up PowerDVD 2.55
post #1 of 7
Hi Gang
Just recieved my Crouching Tiger DVD from: http://www.getvcds.com/dvd/dvdhiddendragon.shtml
It plays well and looks good on my Toshiba player ( region 1), but locks up Power DVD 2.55 every time. As soon as I hit the play button on PowerDVD it locks up, I have never had this problem before. Has anyone had any luck playing this DVD in PowerDVD?
Any help would be appreciated.
Thanks, Glenn
post #2 of 7
Well the official Region 3 disc plays just fine in PowerDVD, maybe you should send back your Region 0 bootleg and buy the Region 3 instead.
Bob H.
post #3 of 7
Robert
Where can one purchase the region 3 disc? Is PowerDVD a region 'free' player?
Thank you, Glenn
post #4 of 7
<font face="Verdana, Arial" size="2">Originally posted by ghoniba:
Robert
Thank you, Glenn
</font>
Nope, it isn't, although you can download DVD Genie or some similar program to get around it.
None of it matters unless you have an older DVD-Rom "drive" that isn't region locked in the firmware (general rule of thumb is 4x dvd-roms and slower are not, although it really depends on when they were manufactured).
You can get a program to check whether your drive is region-locked, programs such as the aformentioned DVD Genie, test "patches" for firmware to potentially unlock your drive if it is region locked (which you use at your own risk, as it they can also simply hose your drive), and much more information here
Ix
(Ix is the planet of technology in the book Dune, for the non sci-fi geeks out there)
My Opinions may be wrong when compared to yours
View pics of my Home Theater & more at:
www.maximumgamer.com
post #5 of 7
Dude,
Mine "locked up" too on WinDVD2.6.4 when I hit play.
Then I realized all I had to do was hit &gt;| to the next chapter (which was really the beginning) and all was well.
Slight pain to have to hit &gt;| after hitting play (or starting with a chapter select), but small price to pay to have this movie NOW.
MMafia
post #6 of 7
Thanks MMafia,
I'll give it a go, I think I get the hour glass as soon as I hit play and I am unable to do anything else after that.
Glenn
post #7 of 7
Thanks MMafia,
Glenn
</font>
Have you tried Power DVD 3.0? I just did this morning and it worked fine (R0 disk from getvcds.com)
Ix
This thread is locked
