sunra
What gamma setting are you using? The NEC should be set to a 2.2 gamma. If that doesn't fix the loss-of-detail problem (when using the PLUGE pattern in Title 12 Chapter 2 to set black level), try using the Reverse Gray Ramps in Title 12 Chapter 14. The blackest bar is below black -- not sure about the digital level, probably around 12 -- so raise the Brightness control until the black bar next to it (which is at digital level 16) can just be distinguished from the below black bar, then back off 1 click. Black (digital level 16) has 3 white dots above it on the left side of the screen and below it on the right side of the screen.
I was actually considering a 50" NEC last February. Very impressive features and a shitload of adjustment capabilities. Unfortunately for NEC, their black is dark gray. In Plasmaland, Matsushita owns black -- now and for the foreseeable future. That's why I went with the 50" Panasonic 6UY instead.
