@multiblitz:
even when zipped, the quartz.dll is bigger than the maximum size allowed for an upload on this forum.
But the prozess is not painful. It is quite easy actually.
1. Download the hotfix.
2. Run it
3. If you are on an english system, everything is fine.
4. On other language systems you get an error message. Don´t acknowledge the error message yet !
5. Look for a new folder named something like "73907df33e002aa8ba302745" in the root directory of the last partition in your system. ( on my system the folder is created always on the last available partition )
6. Inside that folder you will find a subfolder with the quartz.dll inside.
7. Copy that file to a save location
8. NOW acknowledge the error message from the hotfix installation.
9. The new folder and all the content will be deleted.
10. Now replace the dll:
Download the Windows File Protection Switcher
here
Run it, disable file protection
Then copy the quartz.dll into those two folders:
%windir%\\system32
%windir%\\system32\\dllcache (hidden and systemfolder)
enable file protection again if you so wish, however, it could be possible that windows will replace quartz.dll again if it has access to your windows installation cd.
If you wish to replace the file for all future windows installation you can do it easier than that:
As you can read in
this guide you can put the new quartz.dll (actually, the cabbed quartz.dl_) into the i386 folder of your windows installation base replacing the file in there. That way, you will install the new version every time windows is installed and don´t have to worry about file protection anymore. I have done it like that now (until a German hotfix arrives, so keep a backup of the original quartz.dll and quartz.dl_)
Hope this helps. It´s not really difficult !
Bye,
Alex
