Originally posted by Scott B
A 1/3 octave analyser has inadequate resolution to identify bass nulls and peaks. This is why I was wondering about the resolution of the analyser in the Velodyne system. If the system does have 1/12 or 1/24 octave resolution, and if each parametric equalizer is assignable in terms of its frequency and bandwidth, then I will be purchasing this system. |
Hi Scott,
I couldn't quote you the exact resolution, but let me tell you how it works.
There is a digital oscillator running all the time inside the DSP. When you are on the sweep screen the oscillator moves up in frequency, covering the frequencies between 15 and 200 in about 3 seconds. You can hear this as a sweep tone that moves up in frequency. The mic is set to record the intensity of the sweep at any particular point in time and graph it on the screen, which corresponds to the frequency being generated at the time. There is an internal table storing about 500 points between the 15 and 200 frequencies. So, there is actually more than one mic reading for each frequency measured. The DSP is running far faster than one point per frequency.
I'm not sure how this translates to resolution but I think it's safe to say that every frequency is adequately measured and reported on. And, the exact frequency, level, and Q can be set for each EQ.
Hope this helps,
Bruce
