AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Official Pioneer VSX-1015TX Thread
Official Pioneer VSX-1015TX Thread - Page 64
post #1891 of 2324
Searching the thread didn't turn up a solution for a problem I've run into. I decided to hook up my Xbox 360 through the 1015 and I'm using the component connections to do so. It works fine except it converts the pic to 480i no matter what I set it to.
I read a cryptic reference on page 15 about turning off the Video Processor Mode but do not see how to do it. How can it be done, will it stop the 1015 from converting the P to i mode?
post #1892 of 2324
Bump.
Anybody know the answer?
post #1893 of 2324
I'm not familiar with either model, but the manual for the 1016 says high-definiton progressive component video can not be converted.
Could it be that the OSD uses 480i?
For the 1016, it looks like it is under:
6. Other Setup, e. Video Conv. Setup.
The manual for the 1015 doesn't show this, but it might be in the same place.
Let me know if this works, I've been looking at an open box 1015, but just can't decide if it would be an upgrade from my current AVR.
JayMan
post #1894 of 2324
How do you have the Xbox hooked up?
xbox ----component----> 1015 -----component----> tv
I have no problem getting my 1015 to pass 1080i from my cable box through it to the tv.
post #1895 of 2324
It is not a receiver problem, I can pass both 720p and 1080i from my PC through 1015 to my Hitachi plasma tv. Check your Xbox or tv or may be cables are not good enough.
post #1896 of 2324
Originally Posted by JayMan007 View Post
I...For the 1016, it looks like it is under:
The manual for the 1015 doesn't show this, but it might be in the same place...
FWIW, it isn't. There is no 6e in the 1015 setup menu. The real screen is just like the one shown in the manual.
As others have said, the 1015 will pass a 480i, 480p, 720p or 1080i signal through the component in/out. The 1015 doesn't upcovert, so the output signal will match the input, whatever that was.
Composite and S-video are limited to 480i, so any device attached via one of those will output a 480i signal, even if receiver's component video output is used.
post #1897 of 2324
just a question on the MCACC. When I have the receiver running the way it came out of the box its great however when I run the mcacc the db in all the speakers are lower. Whyd oes the mcacc lower the db? The mic is placed eye level where i sit!
also how does the volum control show up on my benq pe7700 projector
post #1898 of 2324
MCACC calibrates all your speakers to output at reference volume when the volume is set to 0. I believe reference is 110db. Depending on how efficent your speakers it might become necessary to give them different db's to do this.
As far as I know, you can't get the volume to show up on your projector - I think this can only be done using a Pioneer Plasma TV via a special cable.
post #1899 of 2324
Originally Posted by ruztew View Post
MCACC calibrates all your speakers to output at reference volume when the volume is set to 9. I believe reference is 110db. Depending on how efficent your speakers it might become necessary to give them different db's to do this.
Did I miss something in the manual? I dont recall having to set the volume for calibration...just wondering here.
post #1900 of 2324
Perhaps I need to clarify... you run MCACC, it automatically adjusts your volume and calibrates your system.
once MCACC is done, if you were to set t the volume to 0, your system should be outputting at 110 db.
post #1901 of 2324
Gotcha - Are you trying to measur it with a db meter?
post #1902 of 2324
No, I have not..
I just remember reading somewhere in the many pages of this forum the whole 110db thing.
post #1903 of 2324
...I believe reference is 110db...
IIRC, THX Reference level is 75db Pink pink noise all channels. At lease that is what I set my reference level to. When I checked the calabration of my speakers using my 1014, I was within a half db or better on all channels. I also up the db on my subs by 5-10 db ( I like my Bass heavy )
IIRC, Pioneer reference volume is 0. I usually have to listen at -10, to -15. Zero is just to loud
j
post #1904 of 2324
FWIW, my experience and set-up with my 1015 is virtually identical to chlngr1970's. When I checked it with a SPL meter, I was very surprised at how accurate the MCACC setting was.
post #1905 of 2324
Why MCACC always set my subwoofer at -10db? I have turned volume knob of my sub at 1/3. 1/2, 2/3, 3/4 and I run MCACC after that and no difference! sub is always at -10db! MCACC also set wrong feet distance for my subwoofer (put 20 feet but I'm sit at only 10 feets). At this time I'm not sure if I need to find a spl meter and try to calibrate by myself because MCACC is not very accurate....
post #1906 of 2324
I think it even says in the manual that the distance that MCACC comes up with for the subs is not accurate; if not there, then at least elsewhere in this thread. The distance for the sub does NOT matter anyway - someone else can explain.
Turn your sub WAY down; mine is on 2 of 12 or so.
post #1907 of 2324
Why do I need to turn my sub down? Wich benefit will I have?.
I turn it down and run Mcacc again?
post #1908 of 2324
Most likely you have too much bass; maybe to your personal taste you like it that way. If you like your bass set high, then keep it that way and don't worry what MCACC says.
As for why the distance is wrong, sub woofers are non-directional. It is VERY hard to figure out where such low frequencies are coming from and why they can be placed nearly anywhere in a room.
post #1909 of 2324
MCACC is limited to a 10dB adjustment. If you are always getting -10dB, it means it is trying to turn your sub down, but can't take it far enough to give you a flat response.
I'd recommend turning your sub's amp down as others have suggested. Rerun the MCACC until you get a reading of -5dB or less. That will give you a "flat" bass level, at least to use as a reference point. Many people manually adjust it upward by 3-5dB after that. This compensates for the ear's lack of sensitivity to bass sounds at lower volume levels.
One thing to keep in mind is that if your room has a resonant peak, the MCACC will read that and adjust the whole bass setting downward, resulting in dull sounding bass except around the peak. To check for this, you would need a SPL meter and test disc. (The details of subwoofer calibration is a bit outside the scope of this thread, but there is a forum devoted to subwoofers if you want to pursue it.) Otherwise, adjust by ear, seeking a compromise between "boomy" and "flat" smooth response.
post #1910 of 2324
Ok I will try to lower volume knob on my sub and run again MCACC to see if Sub will be other than -10db. If I undestand correctly it doesn't matter if my sub volume knob is set at 1/10 because VSX-1015 will give 'more decibels' to my subwoofer anyway to have it equally calibrate with my others speakers.
post #1911 of 2324
It matters.
If you set the sub volume too low, the MCACC will do the opposite from what it's doing now, moving to +10 trying to turn your sub up high enough. I'd start by lowering it to maybe 1/2 of where it is now. It may take a couple of tries before you hit the right spot. (The 9:00 or 10:00 position is commonly used as a starting point, but there are too many variables to know in advance if it will be right in a given situation.)
The ideal is for the receiver sub setting to be a bit less than zero (around -5dB, give or take a little). That gives you some latitude for subsequent adjustment without introducing possible distortion.
post #1912 of 2324
Ok I just need to find 'spot' area where MCACC will set my sub around -5db. At this point I know this setting is 'balanced' with my other speaker and if my tastes are for more Bass I can add more DB manually.
Thanks again for your great post!
post #1913 of 2324
It matters.
I have tried yesterday to lower volume (1/10) and run MCACC. It was interesting because I received the message volume was to low on my sub!. I have try to turn up higher volume knob and run MCACC again and know I have +0.5db setting for my sub (other speaker are in -3db to -1db range). I have tried to play one of my favorite LFE DVD (LOTR, Moria Mines) and bass was really great!! I have move my sub a little bit out of the corner also (now 2 feet away from corner) and it play very well.
Anyway MCACC really check all parameters to have good balanced setting and If i move a little bit my sub or play with volume knob it can do a big difference As I can see!!!
post #1914 of 2324
I have been struggling trying to get a true dolby digitial sound from my PC while connected to this receiver.
I found the SPDIF bypass in my software for my Audigy Platinum but when I turn that off I get no sound whatsoever.
Anyone have a similar setup and able to get a true dolby digital sound from their receiver while connected to a PC.
I am willing to try anything at this point.
Thx.
post #1915 of 2324
Try the HTPC forum. Someone there will probably help you troubleshoot it. Make sure the optical input on your AVR is assigned to DVD. If not that then it sounds like a pretty simple fix, like there's a setting a-scew somewhere.
post #1916 of 2324
I have my AVR set to Video 2.....I thought this is what it needed to be to connect to my PC.....I use DVD for my DVD Player.
I also have a thread in HTPC.
post #1917 of 2324
Thx.
I have my Audigy 2 hooked up via 50' of RG6 SPDIF to my 1015 and get perfect Dobly Digital when playing DVD's on the PC.
Under the Creative "Device Controls - AudoHQ" Decoder TAB, you must have "SPDIF Passthrough" checked. Other than that, there are NO other settings in the Creative drivers you should need to set to get Dolby out.
If the DVD software you are using has an audio setup, make sure that it too is set to use the SPDIF and not Analog sound.
post #1918 of 2324
Are you sure it says "SPDIF bypass". I thought it was "SPDIF Passthrough" like Grimdeath said. If it does say passthrough then you must have the box checked to get the digital signal to "passthrough" to your receiver.
I would also agree that your DVD software has to be set to digital and not analog. That one bit me a couple of times.
post #1919 of 2324
Hi guys,
I have a question for 1015 expert!,
I just checked my surrounds speakers technical specs to know how well they can handle LFE signals and I've discovered that my speakers can not goes under 80hz according with user manuel!, I know sometimes user manuels specs may be exagarate and I know my crossover in my receiver is set to 80hz.
Now my question: Can I trust my receiver for sending all below 80hz LFE signals to my PowerSubwoofer? Is it possible that some 70hz or 60hz tones 'slipped' to my surrounds speakers because receiver is not accurate and losts these signals because my surrounds speaker don't goes at this level?
post #1920 of 2324
Hi guys,
As long as you have your rear speakers set to "Small" all signals below your XO (80hz) will be routed to the sub. If you have a descent sub I believe it is recommended that you set all your speakers to small and let the sub do all the low end work. If your sub will support upto 100hz, it might be better to change your XO to that to avoid pushing your rears to their limits.
I'm not sure exactly how precise the 80hz XO setting is, but I've never heard anyone mention otherwise.
