AVS › AVS Forum › HDTV › Local HDTV Info and Reception › DirecTV siginal strength
post #1 of 7
What should i be getting on the 101 & 119 ?
I am currently getting 82 on the 101 & 70 on the 119.
I have a clear view and think this is low any thoughts ?
Ti's not 0 to 60 that counts ! It's 60 to 0 that does !
post #2 of 7
No, that is pretty good. 119 will have a lower ss until August when the new satellite launches.
What is popular is not always right.
What is right is not always popular.
It is better to be quiet and thought a fool than to speak and remove all
doubt.
post #3 of 7
What new satellite are the launching ?
post #4 of 7
Doing a few WWW searches, I found this site, which lists a satellite called "DirecTV 5" as having a launch date in August.
I also found another site with a list of their satellites:
DBS 1 110° DIRECTV 1
DBS 2 101° DIRECTV 2
DBS 3 101° DIRECTV 3
DIRECTV1-R 101° DIRECTV 1-R
TEMPO 1* 119° DIRECTV 5*
TEMPO-2 119° DIRECTV 6
DIRECTV 4-S* 101° DIRECTV 4-S*
* = To be launched
It shows that there are three satellites at 101°, do they operate simultaneously, or are they there for redundancy?
I think the DirecTV 4-S satellite is the one with "Spot Beam" technology to enable directed local channels.
Does anyone else have more detail about the new capabilities of DirecTV-5? Or, how they operate together with multiple satellites in the same orbital position?
post #5 of 7
I have read somewhere that DirecTV is going to put ALL of there HD on the 110 bird any info on this ??
post #6 of 7
I think that is a recurring rumor on these discussion boards. As far as I can tell, there has been no verification that new HDTV programming is coming on 119 or 110.
post #7 of 7
Not familiar with your part of the world but I get low 90s on 101 and low 80s on 119. I live in central Florida. That might make a difference.
After thought: Did you check to make sure your antenna settings are those recommended by antenna manufactor? I use the Sony HD100. I thought I could improve on the installer's work but found out that he got the highest signal strength--but I had to learn for myself.
This thread is locked
