AVS › AVS Forum › Video Components › DVD Players (Standard Def) › denon dvd 3910 new firmware version -8
post #1 of 7
hey guys i just checked the denon site and i see version -8 firmware, is this the denonlink/sacd firmware upgrade we have been waiting for...i thougt the the last announcement was for the next generation recievers using sacd 2.0... if its not then what does this firmware fix on the 3910? kris your input would be great, thanks david...
post #2 of 7
I upgraded my 3910 with ESS6609-8.
According to the Denon information, this firmware "Corrects for black level adjustment and range in Normal Mode".
post #3 of 7
oh, thank you very mucho...do you notice a difference? does everything seem to work the way its supposed to?
post #4 of 7
Everything seems to be the same. Of course I reset all my settings after initialization. Didn't notice anything different in the menu settings (still no DL3).
Picture-wise, seems fine. I haven't sat down for critical viewing, but I'm interested in others' opinions.
post #5 of 7
Does this fix the fact that it resets to Enhanced whenever you change the resolution or turn squeeze mode on?
post #6 of 7
Bill,
I only use analog 480p via component, so I'm not sure if I can answer this question. I never noticed a problem like this via component before.
post #7 of 7
I think it's only a DVI/HDMI problem. Denon emailed me that V. 8 will solve this bug. I'll have a chance to download it tomorrow, and will try it out.
  Back to Forum: DVD Players (Standard Def)
This thread is locked
