I did reply to both your comments. I'm just not familiar enough and don't really understand C-Weighting well enough to chisel in stone a comment about it. My statement included an "I also didn't think" preface and this comment at the end: "Maybe Ilkka could elaborate because I may not fully understand myself." My thinking ain't always accurate and I believe he would be more familiar with this than I would. I have seen comments by some of the more knowledgeable to this effect, or at least I thought they were more knowledgeable.
Without a doubt though, I do know that by using C-Weighting it does NOT make the necessary corrections for the RS mic to be accurate... you DO need correction values for all of the RS SPL meter mics.
I have an older model analog and 3 newer models. I have tested between the older and two of the newer models and they were all three different. It wasn't by much but it was different.
The whole key here is that the old correction values are not adequate... they are way off for any meter I have tested against my calibrated ECM8000. However using the newrs.cal file that John Mulcahy, Ken Bruce and myself created, it will get you closer than any other .cal files I have tested. Due to the variances from meter to meter, you may be off a couple of db but that is much better than being off as much as the old correction values would cause you to be off.
Many moons ago, before I was actually a member here... I say about 5 years ago, there was a guy here on AVS that posted his results of testing the RS Meter and stated the old correction values were accurate... therefore I always used them. I just simply decided to acquire a better mic and have it professionally calibrated so that I wouldn't have to use the RS mic. I decided to test the differences and learned how drastic a difference there is. I came here and noticed Ilkka had done the same.
I posted this above in an earlier post showing the differences between his test and my test:
10 Hz +5 dB vs. +27.00
12 Hz +6 dB vs. +21.91
16 Hz +14.8 dB vs. +16.15
20 Hz +11.5 dB vs. +12.38
25 Hz +7.8 dB vs. +8.80
30 Hz +5 dB vs. +6.50
40 Hz +3.2 dB vs. +3.46
50 Hz +2 dB vs. +2.21
80 Hz +1 dB vs. +0.98
100 Hz +1.2 dB vs. +0.27
We are within 1.5db of each other from 16hz to 100hz which would be a very reasonable difference from one RS meter mic to the next. What I would question is possibly his calibrated mic's accuracy at 10hz and 12hz. I have a problem believing that any RS meter mic is only -5db at 10hz or -6db at 12hz. Our correction values would be more rational when considering what the old ones were... according to the old corrections, 10hz was down 20db... we adjusted it to 27db. At 12.5hz it was down 16.5db and we adjusted it to ~21db.... while he went the opposite direction with his adjustments.
That's about all I know to tell ya.
I'm not sure what happened to Ilkka... I hope he's okay. I've sent him a few PM's in various forums but he's not responded and I noticed he hasn't posted here since March... which is highly unusual for him being he's made almost 2200 posts since Feb 2005.
Btw... I have two brand new analog RS Meters sitting on my table. I plan to measure these against my calibrated mic. I will not need them when finished and will be letting them go for exactly what I have in them and they will include the calibration file with them. I am simply doing this to test between meters. Hopefully I'll get around to this in the next few weeks.
Distribute as you wish.
