AVS › AVS Forum › Gaming & Content Streaming › Digital Recorders (PVRs) General › Can you connect toslink to coax?
post #1 of 5
How do I connect my toslink digital audio output to my home theater system which only has for it's digital input S/PDIF coaxial? My new DVR only has toslink... Please help
post #2 of 5
I use a midiman co2 for this sort of conversion. They allow you to go both from optical to coax, or coax to optical.
Its overkill for what you want to do (since it goes both ways). There are cheaper solutions that will just convert optical to coax.
post #3 of 5
Thanks soooo much! You are a lifesaver!
post #4 of 5
I've bought several of these things on eBay. ABout $15. Make sure you get the one you need: opt-to-coax is not the same as coax-to-opt.
post #5 of 5
Thanks Thinker!
This thread is locked
