In another thread, we think we've come up with a step-by-step guide for a successful installation of the ATI HDTV Wonder hd tv tuner card and another analog tv tuner in Windows XP Media Center Edition 2005.
A few caveats: (1) the procedure assumes a new installation of Windows XP Media Center Edition 2005 on a clean hard drive, (2) the procedure does not apply to a plain Windows XP installation, (3) you will use the latest applicable Windows Updates and drivers, and (4) it is essential that you install a DVD decoder like Nvidia's DVD decoder.
Also, we strongly recommend that you properly analyze your antenna requirements before hand. See AntennaWeb.org and CheckHD.com.
1. Install Windows XP Media Center Edition 2005 without the tv tuner cards. Do the Windows Update. Don't go into MCE to setup TV yet, of course.
2. Install the HDTV Rollup update from Microsoft, if not previously installed
3. Install the analog TV tuner drivers. Shutdown.
4. Physically install the analog TV tuner in the PCI slot. Restart. Check Device Manager
5. Install the HDTV Wonder driver from ATI. Shutdown.
6. Physically install the ATI card in a PCI slot
5. ReStart. The card gets detected and set up automatically. Check Device Manager.
6. Launch MCE and setup TV channels that you want; you need an internet connection.
See our friend "psxjunky" #2 message below for additional important information.
Briefly, the ATI HDTV Wonder will not work in WMCE without the presence of an analogue TV tuner with hardware MPEG encoding unless you use the so-called Kram drivers. The Kram drivers are a hacked version of ATI's Catalyst drivers, the WMCE portion of which is used to make the ATI HDTV Wonder work. However, there are reports that the quality of the TV from the analogue part of the HDTV Wonder is not very good. As this software is not official, you are generally on your own as to getting them to work.
The ATI HDTV Wonder and the Avermedia AverTVHD MCE A180 are presently the only two HD tuners that have been certified for the WMCE "Logo". However, there are other HD tuners that work in WMCE that are not on the certififed "logo" list. For instance, Dvico reports that it's FusionHDTV model works, and has WMCE drivers and instructions on its website.
The ATI HDTV Wonder, the Avermedia AverTVHD MCE A180, and the FusionHDTV will not work in WMCE unless there is also present an analogue tuner with hardware MPEG encoding. As far as we know, there are no hacked drivers like Kram's for the Fusion and Aver cards that will make them work in WMCE without an analogue tuner.
Notes: you can get away with physically installing the analog TV card as you are installing Windows MCE. We don't think it will cause an issue. It is essential that you install a DVD decoder like Nvidia's decoders.
Microsoft says that unofficially Windows XP Media Center Edition 2005 does not support two HD tuners. Like several other users, I can verify that two HD tuners does work in WMCE 2005. I have installed and working an ATI HDTV Wonder and an AverTVHD MCE A180. Two HD tuners makes possible recording two HD programs simultaneously.
A USB analogue TV tuner will serve these purposes as well as a PCI analogue tv card. Hauppauge's USB2 tuner is an example. After setting up the channels in WMCE, you can remove the analogue tuner.
Lastly, your best MCE pc system design is one for a high performance computer. Trying to do this on the cheap or with spare pc parts will increase your risk of a poorly performing system or of outright failure. After all, you will be processing video in all its forms. MS's and ATI's recommended (not minimum) system requirements are good starts.
We do not guarantee that the above procedure will work for you or with all system configurations. We are volunteers, not paid by anyone, and have no connections with Microsoft, ATI, or any other company. To the extent copyright laws are applicable, I grant a non-exclusive right to all individuals for private copying and use. There are no warranties of any kind, and where an express or implied warranty may apply, total damages shall be limited to one centUSA. In other words, use the above at your own risk.
