Originally Posted by
GeekFunk
All these motherboards are different when it comes to figuring out which PCI slot is better than another for a card like the HDTV Wonder.
The issue is trying to avoid having two or more high performance PCI cards sharing the same IRQ. Any card that passes video data trough the PCI bus has to be classified as a high performance card.
If you have video running through the PCI bus from a 1394/ILink port from a miniDV camcorder, then the 1394 card or chipset should also be considered a high performance card. Additionally, if your NIC card continously sends video data or files through your home network, it might be considered a high performance card while it is in action.
So, MadDog500, at the very least we much classify your Nvidia 6600GT, the HDTV Wonder, and the WinTV 150PVR as high performance cards. If any two or three of these cards are sharing the same IRQ, certainly the probability of conflict rises.
The closest I can come to a general rule is that the first PCI slot will be sharing an IRQ with the AGP graphics card, so you don't want to put the HDTV Wonder there. Second, contrary to what many believe, the last PCI slot often shares an IRQ with the AGP card and PCI slot one, so it is often a poor choice. PCI slot three is often loaded with other devices like the USB controllers, so it may be a poor choice also.
I'd try PCI slot four, with PCI slot two as a second choice. However, if there is a card already in four, move it to PCI slot two.
I think that all of the Creative Labs Sound Blaster Cards, Live as well as the Audigy cards, are finicky cards as well. Back in 1998, I wrestled with a Hauppauge WinTV Go card and a Sound Blaster Live card for a month trying to figure out where to put them. Of course, Hauppauge didn't have tuner drivers as good as they are now, and Windows 98 was a BSOD creator.
It might be useless to check the motherboard manual because they are difficult to figure out at times, but that is where one should start.
Argggg! don't remind me! been there/done that!(grin)
I,m Baaaacck! I got a NEW copy of XP pro sp-2 my old copy of XP upgrade got pinholes in the disk somehow,so I could not reinstall it!
Anyway! here,s the problem's:
new install XP......install Nvidia Geforce 6800 GT w/DVD decoder...
Setup HDTV in second slot as it has ONLY the ATI card IRQ active!
run install!
drivers would NOT install.........Install MANUALY.....Working fine IRQ 17 on all!
SiSoftware Sandra
0 : System timer
1 : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
4 : COM1
4 : Communications Port (COM1)
6 : Standard floppy disk controller
8 : System CMOS/real time clock
9 : Microsoft ACPI-Compliant System
11 : NVIDIA nForce PCI System Management
13 : Numeric data processor
14 : Primary IDE Channel
15 : Secondary IDE Channel
16 : OHCI Compliant IEEE 1394 Host Controller
17 : ATI DTV Wonder Analog Audio Capture Device
17 : ATI DTV Wonder Analog AV Capture Device
17 : ATI DTV Wonder Digital AV Capture Device
17 : ATI DTV Wonder Digital BDA Capture Device
18 : Adaptec AIC-7850 PCI SCSI Controller
18 : Silicon Image SiI 3112 SATARaid Controller
19 : Creative SB Audigy
19 : NVIDIA GeForce 6800 GT
20 : Standard Enhanced PCI to USB Host Controller
21 : NVIDIA nForce Networking Controller
21 : Standard OpenHCD USB Host Controller
22 : Standard OpenHCD USB Host Controller
went to install ATI decoder! FAILED cannot find ATI hardware(HUH!)
Wait a min! it's there,and I can PROVE it!(grin)
WHy me! darn it! I just noticed on retrospect,The TUNERS missing(grin) nowonder it did'nt work! I did find out one thing thou,use the single Digital tuner rather than the dual as ATI don't Support the Analog one(what a crock,they have it on the darn card)
anyway just for grins I stuck in my RADeon 8500 and Suprize it worked! mostly
I have ONE problem! ******CRASHING****** sometimes!
I used the WatchHDTV program,which worked right away,real nice!
Nice pictures,I hung it on my outside ANT and it works,don't believe anyone if they tell you to get a NEW ANT! mine goes back to 87 when we moved into this house,and it works great!
In the EVENTS viewer I get this ERROR: Microsoft never heard of it!
The COM+ Event System detected a bad return code during its internal processing. HRESULT was
8007041F from line 44 of d:\\qxp_slp\\com\\com1x\\src\\events\ ier1\\eventsystemobj. cpp.
Now that I,ve programmed the watchHDTV with all the local stations it shows the Screen sounds off for 2 seconds and crashes! I get these Errors in the event log!
The COM+ Event System failed to create an instance of the subscriber partition:{41E90F3E-56C1-4633-81C3-6E8BAC8BDD70}!new:{D3938AB0-5B9D-11D1-8DD2-00AA004ABD5E}. CoGetObject returned HRESULT
8007041F.
Note these two have the same address location
The COM+ Event System attempted to fire the EventObjectChange::ChangedSubscription event but received a bad return code. HRESULT was 80040201.
WMIAdaptor
4099 Error
Open of service failed. This one shows up at the Start and END
Apart from this it looks great when it worked! Now I wonder what will happen if I put my BETTER video card back in(grin)
9/1/2005
Hey! wake up GEEK,where ARE you?
anyway! Put my Nvid back and everything worked fine, EXCEPT !
The picture is like a color Negitive,a little washed out,how can I change the Color and other things?
9/2/2005
HULLO! ANYONE HOME?
Just for laughs:
got this back from ATI:
The HDTV will work with the Radeon 9600 or higher (not with an 8500 series card).
We are not sure how it worked with the Radeon 8500 series card, but HDTV requires directX 9 on a hardware level, the video card you have supports only directX 8 (on a hardware level).
The previous info you relayed to us indicates you have an Nvidia 6800 card?
YET!
Ahhhh! Previous info:
Ok! Since I last sent post! I
installed my Radeon 8500 I had and everything else installed.
I use the WatchHDTV program to setup the TV as the only thing I got on the Multmedia program was EASYShare,no TV setup!
now as I was setting up the TV I sometimes got dumped!
Once I got all the Stations setup,activating the TV would cause a complete CRASH! REBOOT!
I would get sound and video for about 5 seconds!
This from Shabu ???? Wonder where Support IS ????(grin) he cannot read that's for sure!!
News Flash! 9/7/05
All working fine! All that was needed was to play a DVD through the system ????
I watched a movie tonight and just for grins I activated the HDTV tuner..and up it came! Woooo!
Boy! am I suprized!
don,t need you after all(grin)
9/6/2005
Tips:
INSTALLING on a XP pro system:
Use a Radeon 8600 or higher,(I used an 8500,it worked,see earlier note) if you can and install ALL ATI,s files!Then install WATCHHDTV program, once finshed and you have video and sound,reinstall the NVIDIA card,you may get a lousy washed out picture as I did,It sounds weird,but it worked,GET a DVD movie and run it on MS Media,after that,it should come up fine! you then can remove most of ATI stuff ...
I can also run my Winfast USB TV tuner II at the SAME time! PERRRFict picture and NO slow down! according to my Info screen 34/43 % CPU time with BOTH!
23/34% just HDTV.....Lovve IT! the remote works too!
Cheers Dennis
