AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Pioneer 503CMX plasma power supply on replacement list! merged thread
Pioneer 503CMX plasma power supply on replacement list! merged thread - Page 2
post #31 of 143
If someone here could be kind enough to post there settings for the 503cmx... Thanks I really appreciate it...
post #32 of 143
My settings are the following, yours might need to be a bit different.
Contrast -11
Bright +2
Color -9
Tint +9
Sharp -7
Auto Power Off ON
Color Temp Middle
Digital NR Low
Clamp Position Auto
Power Control Mode 1
Hope that helps.
post #33 of 143
You may want to check out this site at c/net.
c/net news.com
Pioneer replaces plasmaTV power supplies.
Lists all the models affected.
Says consumers
post #34 of 143
Well, after being away all weekend, I was greeted Sunday night to a lovely "pop". The call to Pioneer was painless, and the tech I spoke to said it was unnecessary to speak to the industrial department for my 433cmx. The only holdup is that there is not a local service tech listed for my area. Does anybody know if Pioneer will travel to fix my display or will they require me to take it to a distant repair facility?
post #35 of 143
I don't know if they will travel or not. You might be able to talk them into talking you through the repair over the phone. If you are handy with a screwdriver you could do it. It's more work taking it off the wall than replacing the part. Just so you know, you lay it glass face down and unscrew the back panel, the power supply is the unit right in the middle, unscrew it and unplug it, and replace with new one. That's it. They will probably require the tech unfortunately.
Come to think of it, the tech who fixed mine mentioned he travels to the other islands for repairs, so maybe there is a chance.
post #36 of 143
Thanks, I'll try to get them to let me do it myself if they won't travel. No way do I want to lug this thing around. The repair sounds very simple, and I don't think I would have any problems. We'll see, I should hear from Pioneer today.
post #37 of 143
Well, I got the call, and I couldn't talk them into letting me do the replacement. Since there isn't a local service tech, it must be shipped to Atlanta. A shipping case will be coming via Watson Shipping/Freight, and I guess the driver and I will load the display. I spoke to the actual tech that will be working on my display, and he assured me that all will be ok and that there is not any kind of backlog. My baby's going on a road trip.
post #38 of 143
locating the Serial Number
If you do opt for the replacement power supply, you will need to give Pioneer the serial number of the unit
It is easy to find without removing the display from the mount:
it can be found underneath the left corner of the frame (on the bottom )
edit: well at least you can find it on the 503: I looked at my HD1000 and don't see it: the frame may be hiding it !
post #39 of 143
The number listed on the website is correct.
You will need your serial number, model number and whether there is an "orange dot" sticky on the back of your TV (if it is there, the factory already upgraded your unit to the new power supply.)
post #40 of 143
I had some literature with my 503 that was written in Japanese, but had the serial #, so check through all the papers that came with your plasma.
post #41 of 143
So what's the consensus on replacing the power supply even though you haven't had a problem as of yet? I have the 503 CMX and I hesitate to do anything that might end up causing me other problems further down the road. (I'm leaning toward Marks opinion that you "don't fix what is not broken") but would like to know what everyone else thinks.
I'd hate to think that if I don't do something now, I might get stuck with having to purchase a new PS sometime in the future, only because I didn't act now and Pioneer withdraws their "free replacement offer" when I need it.
Is it possible to call Pioneer and get an authorization number but hold off on calling a service center until the PS actually goes out? If I called the service center could they order the part and hold on to it for me until I need it installed?
Oh what to do!!! what to do!! (sigh)
post #42 of 143
The tech that fixed mine said you don't need to replace the PS if it's working. It either works or doesn't. I don't see any disadvantage to replacing it though, Pioneer found PS were failing, found out how to improve them, and are switching them out for free. It's not going to mess up your plasma to replace it early IMO. The main advantage to replacing it before it goes out is the scheduling of repair. If you have a service tech locally he can do it in 15 mins. They only order the part after they get authorization. Mine took about a week. On the other hand if you have to ship it to them, I might be inclined to wait. BTW your old PS goes back to Pioneer where it is upgraded and tested and sent back out. Maybe you will get my old one! Good luck.
post #43 of 143
I own a 25 month old 433cmx that works fine but i gave pioner a call this morning after reading this thread .They gave me the local pioneer service company and i gave them a call.the technician knew all about the ps problem and asked me to check the back of my plasma for a blue circular sticker which signifies the power source board has already been changed.Mine had a yellow and white sticker as well as a blue so the technician said i was all set and if i had a problem to call pioneer.He said halfway through the panel assembly work they switched out the boards.Mine had a build date of nov. 2002.I have no idea if this blue sticker appears on 503 models that are okay.Keep in mind this blue sticker thing was told to me by my local Pioneer service center and not the pioneer company themselves but im going with the explanation and hoping for the best.
post #44 of 143
If you have the latest upgraded PS you should have an orange sticker, at least on the 503cmx it's that color.
post #45 of 143
Maybe the 433 had a blue coded sticker-I hope.
post #46 of 143
I took a picture of my 433 before I sent it off on Friday. I'll check tonight to see what color(s) it has. Hopefully, it hasn't already been upgraded.
post #47 of 143
Mattg3
I've 433 and spoke with Pioneer. They told me to look for an orange sticker on the back. No orange sticker than you are likely to have a potentially defective PS. Although, You may want to contact PIO directly to confirm.
post #48 of 143
Thanks,I dont know why my local pioneer service center said to look for a blue sticker?I will give Pioneer another call and let them know about this blue sticker thing i was told since I have that but not an orange one.Ashridharani,do you have the 433cmx which i have?since you are from Ma. also are you dealing with the video workbench in beverly Ma.As your service center?They are the ones who told me about having a blue sticker that would show the power supply was okay. thanks
post #49 of 143
Hi,
Can anyone tell me about where on the back of the 503 the orange sticker should be? Mine is on the wall so I will have to look for the sticker with a mirror on a stick.
tia
Lew
post #50 of 143
Well I called back pioneer and was connected to the consumer division and in fact it is the orange sticker that means you dont need a power board replacement.they are contacting my local service center which claimed a blue dot on the back signified the plasma was fine.Pioneer was great about this but my service center would end up with a lot of dead plasmas with the blue dot information they are going by.
post #51 of 143
Originally posted by lewlew
Hi,
tia
Lew
You might not be able to see it on the wall. The tech put one one the back and one on the frame so it's easy to see. I got mine from Dell in May of 2003 and it did not have the orange sticker. Pioneer should be able to tell you with the serial number info.
post #52 of 143
Hi,
tia
Lew
I believe the sticker(s) are to the inside of where the mounting brackets go on the back. More to left side if you are facing the back. It'll be pretty tricky to get a mirror up there.
post #53 of 143
So far I haven't read any comments that address my original post above.
Could I please get some feedback? It sure would help me make a decision.
post #54 of 143
OTHguy,Im in the same boat as you with a 25 month old perfectly running 433cmx.I got spooked by this thread and gave Pioneer a call and they said i should have the board replaced.I believe somewhere in this thread someone said if the power supply blows you could end up needing to replace the whole unit.hopefully the patr will be available soon to my service center and the replacement will not screw up my plasma since its out of warranty.I didnt want to face a blown board months down the road when this free repair offer goes away.
post #55 of 143
The only part I didn't respond to is about calling Pioneer and the service center. You'll have to ask Pioneer that question. My tech said they have to pay for the part up front and only get reimbursed when Pioneer gets the old one back so I doubt the service center will want to hold the part till you are ready for it. Hope that helps.
post #56 of 143
Originally posted by mattg3
Thanks,I don't know why my local pioneer service center said to look for a blue sticker?I will give Pioneer another call and let them know about this blue sticker thing i was told since I have that but not an orange one.Ashridharani,do you have the 433cmx which i have?since you are from Ma. also are you dealing with the video workbench in beverly Ma.As your service center?They are the ones who told me about having a blue sticker that would show the power supply was okay. thanks
Sorry Mattg3 for the delayed response. Did not get a chance to check the forum recently. Looks like you already got the answer from Pioneer. They gave me a name of the shop in Norwood called The Service Bench...sounds awfully similar to your shop name, different town. I've not called them yet as I'm, like yourself, debating if I need to switch PS if it is working fine.
post #57 of 143
I have one on order to be replaced when it comes into the service center.I figure this time the problems on pioneer but if i wait I may end up paying for the failure myself.
post #58 of 143
Well, my 433cmx is due back from Atlanta on Thursday, 4/14/05. I sent it out on 4/1/05. So two weeks total to ship the thing off, but "my tech" was on vacation last week. I was also mistakenly billed for the freight to Atlanta by Watkins Motor Lines. That was a scary bill...$916.39
Other than that, everything has been smooth sailing. Correspondence with Pioneer and Watkins Motor Lines has been great. The guy from Watkins helped me load the display in its special case, and they always call about four days in advance to schedule a pickup/dropoff. They've also offered to call my work 30 minutes before arrival as well. Hopefully, nobody else will have to go this route, but if so, it was as painless as could be so far.
Brian
post #59 of 143
Matt,
Did they say how long before the part comes in?
post #60 of 143
No but its been over a week.I will post when the work is done
