AVS › AVS Forum › Audio › Speakers › Onix Rocket Measurements By UltimateAV
Onix Rocket Measurements By UltimateAV - Page 3
post #61 of 545
Originally posted by b_sing
Funny, I didn't read anything about a request for photographic samples in this review. I didn't even see a photo in the review.
Then you haven't seen the review. There's a picture of the 200 center on Ultimate AV's homepage. The review has separate pics of the 750's, 200 center, 250's, and 300 surrounds:
http://www.ultimateavmag.com/
post #62 of 545
Rijax actually "won" his Rockets as part of an MLS HT makeover contest. Guess who nominated him for this, Craigsub. Craig and MLS also went to his place to setup his new system. So much for no bias or Craig being an uninterested observer.
post #63 of 545
Originally posted by Harmon
How do you know it's common for "tweaked" speakers to be sent out? I'm sure you have a solid source for this allegation. If you think about it, it's a silly assertion.
A huge amount of time is spent designing a speaker making sure the drivers, crossover, and enclosure work properly together. How are you going to "tweak" one to make it better? With a car it's not that difficult, but with speakers you would practically have to redesign the whole speaker.
What is probably common in the industry is for a pair of speakers that are being sent for a review to be looked over very carefully for any visual or performance problems. Not done here because Mark believed that these were for photography only. The review speakers had been supplied long before.
If you are sending speakers to a photography studio for what you think is only a photo shoot, why would the crossover version matter? Mark and his staff probably paid no attention to whether these were Classics or Sigs. Why would they? Visually the two versions are identical.
This is a large compay's stance on review samples:
AirCeej, I talked to our rep and he would like to avoid getting his dealers involved for the review. Let me explain:
All products that come off of our assembly line are tested against a reference curve for performance; they are then packed up and shipped out. Anything that doesn’t meet the reference is rejected and reworked or destroyed.
All review products go through an additional step and are checked out by our engineering for everything from fit and finish to structural integrity and get to spend some time in the anechoic chamber. After the speaker gets the testing green light is spends 48 hrs getting burned in and then auditioned by Andrew in our controlled listening room before it gets the final thumbs up. Once this is done the product is repacked, usually in a better fashion than original b/c it usually goes by some sort of Courier Company. The product is then received by the reviewer and a follow up phone call from either Andrew or myself is done in case there are any questions. For this reason we only send out reference quality, 100% tested products for review.
As to your second question Mark seemed uncertain as to which model to send for review NOT for photographing. If the Sigs are so much better (supposedly) why didn't he send them and why did he dissuade the reviewer from taking the speakers he wanted? Are the ones requested even worse?
post #64 of 545
there is nothing in the review about a "request for photographic samples".... that info came from the rocket speaker president in another thread
but yes - there are pictures of the speakers in the review - on pages 1 and 2 of the review
post #65 of 545
All true. What a truly generous thing for Mark to do. Not only did he gift me with a wonderful system, but he personally, at his own expense, flew into town to set it up. WOW!
I think it's pertinent to point out that until that time I was an Axiom owner and still am. And yes, Craig nominated me for the makeover. I consider both of them good friends. What has this got to do with the issue at hand. Is this supposed to "expose" my bias. Need I point out that I've already admitted to being a Rocket owner, and having the accompanying bias that goes along with that. Based on the above, I feel it fairly reasonable to have that bias. Wouldn't you? There is no shame in being biased. The only shame would be failing to admit it.
My bias is not the problem here. It your refusal to admit YOURS that is the problem. You apparently "have it in" for internet companies and will go to great lengths to hurt them and their owners. Starting this thread is evidence of that. Your mistake is not owning up to it and pretending that you are just some innocent bystander out to save the buying public from buying these "horrendous" speakers. Horse hockey! Your own words have exposed your bias, even though you refuse to do so.
post #66 of 545
I'm curious what company is that? In any event, I wouldn't call that "tweaking". I consider tweaking to be using better components in a review sample that will make it outperform the stock model. Very hard to do with speakers I suspect.
What you have described is basically what I just said about review speakers being gone over very carefully for any defects. The company you quoted isn't doing anything different to the speakers to make them sound better. They are just making sure that they are operating correctly. The only non-testing procedure is the burn-in, but everyone's speakers are going to get burned in eventually anyway.
BTW, the possibility of tweaking is the main reason that Consumer Reports doesn't accept review samples, but instead buys the products they review through normal channels. Tweaking can be a real issue with some types of products most notably automobiles. Unfortunately, CR's expertise in judging audio and video gear is sorely lacking.
In the other thread here on AVS about this Mark said that the reviewer had those speakers 20 months or more:
"John Gannon had these speakers for something like 20 + months..."
I don't believe the Sig versions were even available that long ago. Probably the reason he had the classic versions of the 750's.
All the conspiracy theories are getting a little silly.
post #67 of 545
Rijax if nothing else you make me laugh at your, well, everything about you. You couldn't be further off. I am against bad products in general. Be they B and M or internet only. Certainly the fact that internet only companies don't seem to have the wherewithal to attempt to convince boutique stores that they have a superior product and should carry their line is a strike against them. I have owned Axiom, Ascend and Outlaw all are remarkable for the money. The Axioms of course being extensively reviewed and measured, as well they started in the early 80s in B and M stores as I used to sell them. There is also a great deal of garbage sold in B and M stores. For someone biased against internet only firms I've owned quite a few don't you think?
You of course with your freebies are extremely biased. My thanks to the gent who PMed me about you and Craig's rationale for defending Rocket so vociferously.
post #68 of 545
I'm curious what company is that? In any event, I wouldn't call that "tweaking". I consider tweaking to be using better components in a review sample that will make it outperform the stock model. Very hard to do with speakers I suspsect.
Mirage.
post #69 of 545
Ah, back to the personal insult. If you are against "bad products" what is this all about. Are you implying that Rocket is a "bad Product"? Did you read the review? Based on the review, It would be a real stretch to say it's a review of a "bad product." And, the mixup between the measured, and the reviewed speakers has been reasonably explained, though you, of course, chose not to believe them. I wonder why?
You'll have to go back to my posts and point out where I've "defended" Rocket. I remember very well saying that I didn't know what went on between these two men, or which story is accurate. I also said that based on my bias I choose to believe Mark. You, on the other hand, are yet to explain why you accuse him, without presenting any proof, of "spinning."
You are also implying that because I was given a wonderful Rocket system, that would be the only possible reason I would question your motives. Trust me. If this thread occurred BEFORE I owned Rockets my reaction would be the same. I have an innate bias against unproven accusations, like yours. Your erroneous insinuation says more about you than it does about me.
post #70 of 545
If the Sigs are so much better (supposedly) . . .
No one said that. They should measure a more neutral frequency response though because their treble response is a little higher than that of the original 750's. I prefer the Sig's, but there are a fair number of classic 750 owners who prefer the originals and have no desire to change. To each his own.
I'm not trying to downplay the imporance of frequency response curves, but I believe there is a lot more to a speaker than that. For instance, having briefly listened to the Ascend 170's and 340m's, I liked the 340's quite a bit better although I understand that the 170 may actually measure a slightly flatter frequency response.
post #71 of 545
You guys know 6FU is a troll, right? Why else would he continue to insult, and to spark a response?
-T
post #72 of 545
Uh, because he got them before the Sig version came out?
You guys are like the people who think NASA didn't land on the moon. You've got an even more far fetched retort every time you're proven wrong.
post #73 of 545
I'm so glad we have people like you on the board to defend each and every one of us from the evils of people like Mark Shifter and Craig. I know I'd much rather have you put a knife in my back than have Mark or Craig do something nice for me!
post #74 of 545
Wow! I've received e-mails and PMs of the marketing brilliance of giving a "HT makeover" to someone who already had a nice set-up of a main competitor's speakers, instead of someone who has a HTiB or nothing at all. But I did not know it was the guy that was briefly a business partner of AV123 that nominated him.
Anybody notice my question about the "midranges" on the 200 has never been answered or that no graph has been given to show different measurements for the 200?
post #75 of 545
This can all get cleared up pretty easily IMO.
UltimateAV I believe is Stereophile.....and they have a pretty good reputation. Mark just needs to write and letter to the editor with an explanation...which I am pretty sure will get published with a response, and then have them do a re-measurement.
pretty simple
post #76 of 545
I can't believe you guys are feeding 6FU like this. If you look at almost all of his other threads, they are all baited for arguement. Feed the TROLL if you must, i've been there and done it with this guy all ready. 6FU you never did explain anything in the thread that you and i both know about. You are a fraud, hack etc, etc. There is a disease gentlemen, and it's called 6FU.
post #77 of 545
Sounds like damage control to me and at the very least it brings into question their quality control. Rocket is 100% OFF my list for future purchases.
Yeah, right. When were they ever on your list. :D
post #78 of 545
Back from Dinner ... and Curtis, Mark has said he would like Stereophile to measure a pair of production 750's ... and yes, that would be a good idea.
6FU ... If you knew Rijax, and everything he has done in his life, you would NOT be disparaging my nominating home in the home theater makeover. He is someone who served in our Armed Forces, and who has shown virtue in many areas of his life.
I was thrilled when he won the makeover, and HE extended the invitation into his home when Mark Schifter was flying in for the install.
He lives all of 2 hours from me, and it was a GREAT evening.
I DID receive a tremendous payback for this, though ... I got to meet Rijax, an Axiom owner and friend of his from Rochester, NY who made the 5 hour drive, Rijax's mother (a DEAR 94 year old woman) and, of course, Mark Schifter.
As for your continued assertion that I have a "vested interest" in AV123 ... you are wrong. YOU live in a world in which people do NOT do things for the good of others, and for that, I pity you.
My biggest problem with this entire line of thinking of yours is quite simple ... YOU are taking pleasure in trying to run someone else (in the case, MLS) down. I loathe that type of behavior ... it is the sign of a mean, petty person.
I really DO feel sorry for you... to be this cynical is a tragedy.
post #79 of 545
Oh shame on you, Quinn. You have absolutely no idea why I was selected for the makeover. Yet you chose to assume it was a marketing ploy, and that there could not possibly be any circumstances that would render me deserving of such a wonderful gift. If it was a marketing ploy, the local media would have been alerted, and a professional photographer would have been present, threads would have been posted all the internet forums, etc. Yes I took a few photographs, as did Mark, and they were posted in a thread on av123 ONLY, in order let the other guys on the forum share in the fun of the day. If Mark's intent was to use this for marketing, I'm sure he would have done a far better job of it than that.
Also, Mark told me explicitly he expected no comparison, on my part, of the Axioms and the Rockets. And I have judiciously avoided making comparisons, even on the av123 forum itself. And if he expected me to become a shill for Rockets, which I don't for one second believe, he failed. Here is a post of mine, made only 6 days ago, where I suggested the Axiom line as an option. The title of the thread is "Onix Rockets and Paradigm Studios."
I have always been, and will continue to be, a supporter of, and exponent of Axioms, and other internet companies like your Ascends. In posts, and PMs to those who have inquired, I have explained that I have never heard the perfect speaker, and the Axioms and Rockets each have positives and negatives. I HAVE said the Bigfoot center channel is the best center channel I've ever owned, which is no more, and no less than the truth, and is only an opinion, NOT a recommendation.
I have always tried, even before owning Rockets to avoid recommending any product, because of the complete subjectivity of our hobby. I have restricted myself, as much as possible, to merely explaining my experiences and leaving it to the reader to make his own decisions. The one exception to the above is the MX-700 remote, which I have unabashedly recommended to everyone, especially Curtis! :D
So, here we have another unfounded, and UNSUPPORTED, implication of skulduggery by someone who has an axe to grind, and is TOTALLY unaware of the facts. It seems beyond your capabilities to believe that Mark would simply want to do something kind for someone, expecting nothing in return. I expected better from you, Quinn.
post #80 of 545
Jack - To take this one step further ... I never WAS a partner with AV123 ... We announced the intent to form the opening of a new territory for AV123 which NEVER actually occured.
Chris Quinn ... I also had nominated Rijax for this makeover last JULY (July 18, to be exact) ... For you to suggest something was worng with my having done so is nothing short of disgusting.
And, for the record, you need to get off your "I got SO many Private messages" nonsense ... You make it sound like legions of people are coming to YOU to air grievances. I have YET to receive ONE PM on this whole matter. Somehow, I find that hard to believe that you are the Oprah of audio ...
post #81 of 545
I guess Craig is an objectivist right up until it tramples on his belief system. Until there is a production model that obviously refutes these measurements, I think everyone needs to relax a little, though the measurements are a little damning, to be kind.
post #82 of 545
Yes...I have read that, but what is really needed, more so than new measurements, is an agreed explanation from Stereophile and Mark. Unless this happens, the speculation will be "something is not right".
Right now, all we are doing, is trampling on each other's beliefs as to what is right to try and prove a point. Some want to believe Stereophile, and some want to believe Mark. It is all amplified because this is the first published measurements of Rockets by an independent and professional publication. I suggest everyone write to Stereophile to help get to the bottom of what happenned.
Jack...you know I love my MX-700! :D
post #83 of 545
So did I. :(
post #84 of 545
Pretty much agree with Curtis here. Only thing I would point out is that there really isn't much of a conflict, if any, in Ultimate AV's version of events and what Mark has said. Only inconsistency I've picked up on is that Ultimate AV believed they were testing Sig 750's and Mark knows or thinks that they were the older version. Maybe the magazine just assumed that they got Sig's since that's the only version being sold right now. Mark said these were speakers that they had held on to for photography requests because they had a particularly nice wood grain. Seems like this could be cleared up pretty quickly.
I hope that Ultimate AV does retest a set, but if there is an improvement, I predict that many on this forum will never accept the new measurements or explanation for the previous measurements regardless of how reasonable it is.
post #85 of 545
You Rocket owners are a sensitive breed. I posted a link to measurements, At no time did I question Mark's reputation, which is stellar by the way, unlike some other IOC engineer wannabes.
It still comes down to these being the measurements that were published and horrendous is not too strong a word. It seems very unlikely that Stereopjile/UAV would allow another set to be sent for measurement as the designer could do any number of tweaks to them thereby putting S/UAV's objectivity into question.
If indeed this was a dreadful mistake and Mark was playing around with the crossovers of the set sent for measurement to see just HOW badly he could get it to sound then this is an awful situation for a small company to find themselves in. However we ONLY have Mark's version of events. There has been no comment from S/UAV and until there is charectorizing his version as spin or damage control is most certainly NOT unreasonable given how badly the they measured and the flap it's caused on any number of boards.
As other's not members of the Church Of Onix have stated to date these are the only professional measurements and "Until there is a production model that obviously refutes these measurements" they stand.
To brand me a troll and rabble rouser for posting this in a seperate thread is total idiocy and shows that the folks doing the name calling would prefer that this issue remain sub rosa.
I've also stated that I have no idea if Rockets are wonderful or lousy as I have NEVER HEARD THEM but they were on a shortlist for purchase as I posted a WTB about 3 weeks ago on the ********** forums. Hardly the workings of a troll.
I also owned many Audio Alchemy products which sounded great and were great value for the money before their unfotunate and untimely demise. And I owned a set of the legendary AP1 speakers.
Maybe Mark can give a free set to anyone who enlists thereby solving the problem of nobody enlisting right now.
post #86 of 545
These two sentences contadict each other. Unless, of course, you consider labeling Mark's version as "spin" or "damage control" (euphemisms for lying) to be complimentary to Mark's reputation. Absent comment from S/AV, i. e. without proof either way, you chose to unreasonably characterize Mark's version as "spin" or "damage control." Why?
When given a plausible explanation of what happened, you could have backed off and taken a stance that was neutral, but you instead, without any proof whatsoever, chose to attack Mark's veracity, and insult all who took exception to that. Without comment from S/UAV, the only reasonable position is "we don't know" what occurred. It appears you've branded him guilty until proved innocent. I think asking why you would do that is logical.
If I understand things correctly the only thing S/UAV can confirm or deny is whether or not they asked for a pair of speakers to be sent to a photographer, and if those were the ones measured. They were not privy to what speakers were sent where, or how they were selected. And, I agree with Harmon that, absent that, nothing will satisfy you because your agenda appears to be the disparagement of Mark and Rocket.
Oh and yes, those of us who call Mark "friend" ARE sensitive to unwarranted, and unsupported attacks on his character. I don't think we could reasonably call ourselves "friend" if we weren't. Maybe your definition of "friend" is different.
By the way, did you serve your country?
post #87 of 545
Actually Joel, I am one who has consistently called for blind or double blind LISTENING tests for speakers and subwoofers. My "belief system" was not trampled here in any way. The LISTENING portion of PRODUCTION speakers was a very positive review.
People seem to have a hard time with the chronology, so here goes ...
1. About 20 months ago, Jack Gannon gets a review sample of 750's (along woth the other speakers ... but to keep it simple, let's stick with 750's) ...
2. Much later (about a year and a half), the written report on the listening tests is almost done, so Stereophile requests some speakers "for photography purposes"...
3. AV123 sends some speakers out which were not normal production speakers, with the thought that they would be photographed and returned.
4. Stereophile is unaware these are not production models, and proceeds to take the photographs AND measurements.
5. Stereophile publishes the listening portion of the review ... which is VERY positive ... and even belies the "750's are laid back" conventional wisdom.
6. Stereophile ALSO publishes the measurements of the "non-production" speakers. THESE results are in no way CLOSE to the results of the listening test.
7. AV123 makes note these were NOT production speakers, and says they will ask for permission to send a "real pair" off the assembly line.
BASED on the above facts, 6FU has decided this means there are rampant QC issues with Rocket speakers.
6FU ALSO states any speakers sent out by AV123 will be "tweaked". If you did NOT have an agenda, you would be calling for Mark Schifter to PUT UP or SHUT UP. THAT would be reasonable... For example, allow Stereophile to ORDER a pair of speakers right off the website with the knowledge they will get a FULL refund after testing is done.
This order could EASILY be done to an "unknown" individual, so there is no way anyone at AV123 would know these were review samples.
GIVING Mark Schifter the benefit of the doubt, and going with HIS assertion the speakers MEASURED WERE ONLY requested as photography samples (he mentioned he still has the e-mail stating so), Stereophile SHOULD allow for such a test ... They, afterall, have been said to have measured speakers which were NOT production models ...
Assuming Stereophile would be willing to do this, ... ALL this controversy could be put to rest. Hopefully they would do the same methodology they normally follow, including breaking the speakers in ... etc... and would post a complete follow up.
As far as this "Rocket owners are a sensitive bunch" nonsense, I have had the same types of conversations regarding Klipsch, Paradigm, Axiom, and several other speakers with which I have had first hand experience and have seen others trash.
On an ironic note ... I HAVE measured the following speakers with my Earthworks microphone and ETF software, and HERE are the measured results from 200 to 20,000 Hz: Paradigm 100 v.3 +/- 2.8 dB ... Ascend 340's +/- 1.5 dB... Axiom M22-ti's +/- 3.6 dB... Rocket 550 Mark II's +/- 2 dB... Rocket 750's +/- 3.1 dB... Klipsch Belles +/- 5.3 dB... Ascend 170's +/- 2.2 dB ... PSB Stratus Silveri's +/- 1.4 dB... Klipsch RB-5's ... +/- 4.4 dB ...
Nine systems measured ... Two were Rockets ...
post #88 of 545
Damage control does not necessarily imply lying. It's simply a matter of one side explaining away something that is negative. It may very CLEARLY be the honest version but until there is comment from both parties it most definitely is a spin for damage control. Why would you choose to focus on the negative aspect of DC and spin rather than the positive? Perhaps you don't quite understand the meaning?
Until UAV comments you are exactly right we don't know. We don't know if Mark is telling the truth or if the measurements are the truth. I have not attacked anyone rather it's quite the contrary. At this moment in time the measurements are the first and only by a respected magazine to be published and we have Mark's version of what happened. Could he be telling the truth ABSOLUTELY, could he be lying about it to save face ABSOLUTELY. Either scenario is entirely plausible. Given Mark's reputation I would doubt he IS lying but it remains a valid possibility.
I have no agenda and if you read S-L-O-W-L-Y you will see I posted a WTB Rockets message on AV123 3 weeks ago. I have said nothing disparaging whatsoever you and others just seem incapable of accepting the fact that it is possible that is how they measure OR there's a serious QC issue at Onix.
His character has not been attacked and of course he's your friend he gave you a free speaker setup!:D
No in my country serving means to randomly crash outdated helicopters at regular intervals and not demeaning POWs.
post #89 of 545
Hey, packing MRE (Meals Ready to Eat) for the troops doesn't count as serving (well...unless you're serving at the mess hall) :D.
post #90 of 545
Yeah we really have to work on getting some toughness. :D
  Back to Forum: Speakers
This thread is locked
